Interval Proxy Day Estimation
This rule checks for days with similar temperature and uses the measurement data from those days as the basis of interval estimation for the in-flight initial measurement.
Measuring component comparison periods are used as the main driver for determining similar temperature days.
Additional detail on the logic of this rule can be found in the Detailed Description of the D2-INTPROXY Algorithm Type.
For help with the meaning of specific configuration fields, refer to the embedded help on the screen when adding or editing the rule.
Business Object
D2-IntervalProxyDayEstimation
Parent topic
