Maintaining Contacts
This portal is used to display and maintain a Contact.
You can access the portal from Menu > Usage > Contact. You are brought to a query portal with options for searching. Once your record has been selected you are brought to the maintenance portal to view and maintain the selected record.
• Contact: defines the basic attributes of the contact
