Maintaining Dynamic Options
This portal is used to display and maintain a Dynamic Option.
You can access the portal from the Menu > Usage > Dynamic Option. You are brought to a query portal with options for searching. Once your record has been selected you are brought to the maintenance portal to view and maintain the selected record.
• Dynamic Option: defines the basic information about a Dynamic Option.
• Dynamic Option Event List: provides a list of the Dynamic Option Events that have been created for this Dynamic Option.
