Meter Attribute | Definition |
id | The meter identifier. This value should match the amiDeviceID setting in the Oracle Utilities Application Framework. |
utility | This is informational only. |
serviceType | This is informational only. |
ServiceType | An enumeration that is described in the schema. |
isCommissioned | A boolean value that describes whether or not the meter is commissioned or decommissioned. The associated MultiSpeak commands are MeterAddNotification and MeterRemoveNotification. |
loadActionCode | This value is for the Connect and Disconnect commands and has enumeration values described in the schema. The value is returned in the CDStatesChangedNotification MultiSpeak command. |
outageEventType | This value is used by DeviceStatusCheck and gives the status returned by the ODEventNotification call. Its enumeration values are described in the schema. |
executionStatus | This value does not reflect a MultiSpeak command, but is instead intended to give a state of the operation. There are four valid values: Success: When a meter has this status the operation will complete without error. ResponseTimeout: When a meter has this status an asynchronous reply will never arrive (not relevant for Commission/Decommission commands). SyncOperationFailure: When a meter has this status the initial communication to the simulated head-end system will produce an error. AsyncOperationFailure: When a meter has this status, the asynchronous callback from the head-end system will arrive, but will indicate an error (not relevant for Commission/Decommission commands). |
Channel Attribute | Definition |
uomCode | The units of measure code that should be returned when the meter is read. |
uomName | The units of measure name that should be returned when the meter is read. |
description | A longer form. When the meter is read, a random number is generated for this value. |
decimals | A value to indicate how many places to the right of the decimal that random number should have. |
