Service XML Button
The Service XML button switches to the Service XML viewer. This button is not available when you are already in the Service XML viewer.
You are prompted to enter the name of the service XML file you want to view. The name of the service XML file should be entered without the extension. Note that only service programs that are Java based or Java (converted) are applicable here. There are some Services in the application generated for portals. There is no XML for those services.
Parent topic
