To Do Summary Zone
The To Do Summary Zone has several purposes:
• It presents a summary of the
To Do entries that have been assigned to you and are
Being Worked On.
• The colored "age bars" highlight the age of the To Do entries. The colors red, yellow and green are used to highlight the relative number of old, middle-aged and new To Do entries. The age associated with each of these colors is
user-configurable. Note, you can hover the cursor over an "age bar" to see the number of To Do entries.
• If you click on the To Do Type description or on an "age bar", you'll be transferred to the
To Do List transaction where these To Do entries will be displayed. From this page, you can drill down to the specific entries.
Note:Time saver! After you drill down on entry from the
To Do List page, if you have the
Current To Do zone configured in the dashboard, you can use the
Previous To Do and
Next To Do buttons in the zone to scroll through additional To Do list entries without returning to the
To Do List page.
Parent topic
