Preparing the Production Database
If the production database does not exist create the database under the production schema owner (CISADM).
Note: If the production database is upgraded from the previous version of the application make sure all public synonyms that are created on the application tables are deleted. Instead, each application user should have private synonyms created on the application tables in order for the conversion tool configuration to work.
