Table | Type of Table |
F1_MIGR_REQ_INCL_REQ | Migration request Grouping |
Table | Column | Required |
CI_BATCH_CTRL | APP_SVC_ID | Y |
CI_XAI_RCVR_CTX | SEQNO | Y |
CI_XAI_SNDR_CTX | SEQNO | Y |
F1_IWS_SVC_ANN | SEQ_NUM | Y |
F1_MIGR_REQ | MIGR_REQ_CAT_XFLG | N |
F1_MIGR_REQ | MIGR_REQ_CLASS_FLG | Y |
F1_MIGR_REQ_INSTR_ENTITY | COMMENT_LONG | N |
F1_MIGR_REQ_INSTR_ENTITY | EXT_REFERENCE_ID | N |
Table | Column |
CI_XAI_RCVR_CTX | CTXT_VAL |
Table Name | Column Name | From | To |
F1_EXT_LOOKUP_ VAL_CHAR | F1_EXT_LOOKUP_ VALUE | VARCHAR2 (30) | VARCHAR2 (254) |
Table | Primary Key Columns |
CI_XAI_RCVR_CTX | XAI_RCVR_ID, SEQNO |
CI_XA_SNDR_CTX | XAI_SENDER_ID, SEQNO |
