Supported Database Platforms
This section defines the platforms on which Oracle Utilities Smart Grid Gateway is verified to operate.
Supported Platforms Summary Table
Oracle Utilities Smart Grid Gateway is certified on the following platforms:
Platform
Database Version
AIX 7.2. TL5+ (POWER 64-bit)
Oracle DB 19c (64-bit)
Oracle Database Server 19c
Oracle Enterprise Linux 8.x x86_64 (64-bit) (Based on Red Hat Enterprise Linux (64-bit))*
Oracle Solaris 12 (SPARC 64-bit)
Windows Server 2012 R2
(x86_64 64-bit)
* Oracle Utilities Smart Grid Gateway is tested and supported on the versions of Oracle Linux specified. Because Oracle Linux is 100% userspace-compatible with Red Hat Enterprise Linux, Oracle Utilities Smart Grid Gateway also is supported on Red Hat Enterprise Linux for this release.
Windows Server is not supported for Production environments. Wherever Windows Server is referenced within this guide, it is supported for Test or Development environments only.
The following Oracle Database Server Editions are supported:
Oracle Database Enterprise Edition 19c
Note: Oracle Database Enterprise Edition and the Partitioning and Advanced Compression options are strongly recommended in all situations.
Visit My Oracle Support for additional details.
Support for Software Patches and Upgrades
Due to the ongoing nature of software improvement, vendors issue patches and service packs for the operating systems, application servers, and database servers, on top of specific versions that Oracle Utilities Smart Grid Gateway has been tested with.
If it is necessary to apply an upgrade, please do so in a test environment that is running on the same platform as your production environment prior to updating the Oracle Utilities Smart Grid Gateway production environment.
The exceptions from this rule are Hibernate software V4.0 GA and the Oracle Client V12.1.0.1. These versions should not be upgraded.
Always contact Oracle Utilities Smart Grid Gateway support prior to applying vendor updates that do not guarantee backward compatibility.
