Compression Recommendations
It is highly recommended to use the following guidelines with regard to compression.
1. For all transactional data tables including ILM enabled tables (except D1_MSRMT* tables):
a. For easier operational manageability, it is recommended to enable the compression at tablespace level while creating separate tablespaces for each logical unit of archival (like a parent table partition and the corresponding referenced child table partitions).
b. Use securefile medium compression for LOBs.
c. On Oracle database 19c:
Use advanced compression for table data compression.
Compress indexes using advanced low compression (using ‘compress advanced low’ clause).
2. For D1_MSRMT* tables:
a. Keep current table partitions uncompressed for D1_MSRMT. Other D1_MSRMT* tables should use compressed tablespaces for all partitions.
b. For the D1_MSRMT table- Periodically (recommended monthly), compress the data by reloading into a staging table followed by partition exchange. It is highly recommended to use bulk load CTAS operation with parallel clause during the reload.
Use ‘QUERY HIGH’ compression for Exadata implementations.
For non-Exadata implementations, on 19c use ‘row store compress advanced’.
c. For indexes:
On Oracle database 19c, compress indexes using advanced low compression (using ‘compress advanced low’ clause).
