Before You Install
Visit My Oracle Support for up-to-date additional information about installing Oracle Utilities Smart Grid Gateway.
WebLogic Native Installation
With Oracle Utilities Application Framework 4.5.0.1.0, a WebLogic native installation is required. Refer to the Oracle WebLogic 12.2.1.x Configuration Guide for Oracle Utilities Framework (Doc ID 2413918.1) document on My Oracle Support for more information.
Application Server Clustering
If you are considering application server clustering, refer to the Oracle WebLogic 12.2.1.x Configuration Guide for Oracle Utilities Framework (Doc ID 2413918.1) document on My Oracle Support.
Additional information about WebLogic clustering, refer to the Fusion Middleware Using Clusters for Oracle WebLogic Server documentation.
Directory Names
Directory cannot contain whitespace characters.
Prerequisite Software List
Before you install Oracle Utilities Smart Grid Gateway, you must install prerequisite software.
Refer to the respective installation documentation of the software for instructions on downloading and installing.
Prerequisite Software for Database Server
The prerequisite software for the database component of Oracle Utilities Smart Grid Gateway is as follows:
• Oracle Database Server 19c - This is required for installing the database component of the Oracle Utilities Smart Grid Gateway product. The following version of the database server is supported:
• Oracle Database Enterprise Edition
Important: Oracle Database Enterprise Edition and the Partitioning and Advanced Compression options are strongly recommended in all situations.
Prerequisite Software for Application Server
The prerequisite software for the application component of Oracle Utilities Smart Grid Gateway is as follows:
• Oracle Database 19c Client
• JDK 1.8.0_291+ (64-bit)
• Oracle WebLogic 12c (12.2.1.4)
Note: Only WebLogic Fusion Middleware Infrastructure Installer should be used.
• Hibernate 4.1.0 Final
• Oracle Service Bus 12.2.1.4
Oracle Service Bus is required for an implementation that plans to use a productized adapter or the Adapter Development Kit to process meter reading or device event data.
Note: Oracle Service Bus 12.2.1.4 requires Oracle WebLogic Server 12.2.1.4.
• Oracle SOA Suite 12.2.1.4
Oracle SOA Suite (specifically, BPEL Process Manager) is required for middleware implementations that plan to use a productized adapter or the Adapter Development Kit to implement two-way communications for processing meter commands.
Note: SOA Suite is NOT required with native implementations of Smart Grid Gateway adapters. See Smart Grid Gateway Implementations in the Oracle Utilities Meter Solution Administrative User Guide for more information.
Oracle Security Fix Updates
It is recommended that you keep the Oracle prerequisite software up to date with the latest security fixes provided by Oracle.
Web Browser Requirements
The web browsers listed below are supported when used on each of the operating systems indicated:
Browser
Windows Operating System
Microsoft Edge for Business 81+ (Edge Chromium)
Microsoft Windows 10 Version x 64-bit
Mozilla Firefox ESR 91.x
Google Chrome Enterprise 81+
Apple Mobile Safari
Apple iPad iOS 15.x
