Customizing the Logo
To replace the Oracle Utilities logo on the main menu with another image, put the new image <customer_logo_file>.png file into the directory $SPLEBASE/etc/conf/root/cm and create a new “External” Navigation Key called CM_logoImage. To do that, run the Oracle Utilities application from the browser with the parameters: http://<hostname>:<port>/cis.jsp?utilities=true&tools=true.
From the Admin menu, select Navigation Key.
Add the above Navigation Key with its corresponding URL Override path.
The syntax for the URL path is:
Windows
http://<host name>:<port>/<Web Context>/cm/<customer_logo_file>.png
UNIX
The root directory may be deployed in war file format for runtime environment (SPLApp.war). Use provided utilities to incorporate your cm directory into SPLApp.war file0
