Relationship Between 2.5.0.1.1 and Prior Versions
V2.5.0.1.1 supports the following upgrade paths:
If you are installing Oracle Utilities Smart Grid Gateway for the first time, you must install V2.5.0.1.1, available on the Oracle Software Delivery Cloud.
If you have Oracle Utilities Smart Grid Gateway V2.1.0.2 or earlier installed, you must upgrade to V2.1.0.3 and then to V2.5.0.1.1.
If you have Oracle Utilities Smart Grid Gateway V2.1.0.3, you can upgrade to V2.5.0.1.1 directly.
If you have Oracle Utilities Smart Grid Gateway V2.2.0.1 or V2.2.0.2 installed, you must upgrade to V2.2.0.3 and then to V2.5.0.1.1.
If you have Oracle Utilities Smart Grid Gateway V2.2.0.3 or later installed you can upgrade to V2.5.0.1.1 directly.
