Hardware Requirements
The following section outlines the client side hardware requirements for Oracle Utilities Smart Grid Gateway:
Configuration
Processor
Memory (RAM)
Storage
Monitor (Display)
Minimum
2 gigahertz (GHz) or faster with 2 or more cores *
8 GB **
128 GB or higher ***
Refer to Redwood Large resolution (currently 1024px)
Recommended
3 gigahertz (GHz) or faster with 2 or more cores *
16 GB **
250 GB or higher ***
* or comparable processor
** more RAM may be needed for more graphic intensive application features such as WAM's GIS Viewer or CM Portals that contain numerous graphs
*** to support browser caching
Note: The hardware requirements listed above are based on running the application only, and without any additional software running concurrently. If your client setup requires other software running, please adjust the requirements to account for them.
