Upgrading from Oracle Utilities Smart Grid Gateway V2.3.0.2.0 to V24.5
New Tables
Table_Name
D1_ACTIVITY_TYPE_DIV
D1_ACTIVITY_TYPE_FLD_TASK_TYPE
D1_CONTACT_COMM
D1_CONTACT_COMM_CHAR
D1_CONTACT_COMM_K
D1_CONTACT_COMM_LOG
D1_CONTACT_COMM_LOG_PARM
D1_CONTACT_COMM_REL_OBJ
D1_DVC_ENTITY_GRP
D1_DVC_EQPMNT
D1_DVC_TYPE_VALID_DVC_CHAR
D1_DYN_OPT_QTY
D1_DYN_OPT_QUESTION
D1_DYN_OPT_RATE
D1_DYN_OPT_RULE
D1_DYN_OPT_SPECIFICATION
D1_DYN_OPT_TYPE_QTY_TYPE
D1_DYN_OPT_TYPE_REL
D1_DYN_OPT_USG_GRP
D1_ENTITY_GRP
D1_ENTITY_GRP_CHAR
D1_ENTITY_GRP_CRIT
D1_ENTITY_GRP_CRIT_VAL
D1_ENTITY_GRP_L
D1_EVT_PARTICIPATION
D1_EVT_PARTICIPATION_CHAR
D1_EVT_PARTICIPATION_K
D1_EVT_PARTICIPATION_LOG
D1_EVT_PARTICIPATION_LOG_PARM
D1_FACILITY_SP
D1_IMD_CTRL_STAGE
D1_IMD_CTRL_STAGE_K
D1_IMD_TYPE
D1_IMD_TYPE_ALG
D1_IMD_TYPE_L
D1_MSRMT_AUDIT
D1_RULE
D1_RULE_CHAR
D1_RULE_L
D1_RULE_PARM
D1_SPR_PROG
D1_SP_ENTITY_GRP
D1_SP_TYPE_DISCONNECT_LOCATION
D1_SP_TYPE_DIV
D1_SP_TYPE_FIELD_TASK_TYPE
D1_US_TYPE_VALID_US_CHAR
Dropped Tables
None
New Views
View_Name
D1_ACT_DVC_SP_VW
D1_BI_DYN_AGG_VW
D1_MC_TYPE_PER_EST_EVAL_VW
D2_MEASR_QTY_AGR_MV
D2_MEASR_QTY_MV
D2_QUALITY_CNT_AGR_MV
D2_QUALITY_CNT_MV
D2_TIMELINESS_CNT_MV
D2_TIMELINESS_QTY_MV
D2_TIMELINES_CNT_AGR_MV
D2_TIMELINES_QTY_AGR_MV
Deleted Views
None
New Indexes
Table_Name
Index_Name
D1C636P0
D1C631P0
D1_CONTACT
D1M180S0
D1_CONTACT_COMM
D1T653P0
D1_CONTACT_COMM
D1T653S1
D1T655P0
D1T655S1
D1_CONTACT_COMM_K
D1T654P0
D1_CONTACT_COMM_LOG
D1T656P0
D1T657P0
D1T658P0
D1_DVC_ENTITY_GRP
D1M674P0
D1_DVC_ENTITY_GRP
D1M674S0
D1_DVC_EQPMNT
D1M629P0
D1_DVC_EQPMNT
D1M629S0
D1C634P0
D1C634S1
D1_DYN_OPT_EVENT
D1T230S1
D1_DYN_OPT_EVENT
D1T230S2
D1_DYN_OPT_EVENT
D1T230S3
D1_DYN_OPT_QTY
D1M659P0
D1_DYN_OPT_QUESTION
D1M646P0
D1_DYN_OPT_RATE
D1M645P0
D1_DYN_OPT_RULE
D1M647P0
D1M638P0
D1C660P0
D1_DYN_OPT_TYPE_REL
D1M648P0
D1_DYN_OPT_USG_GRP
D1M652P0
D1_ENTITY_GRP
D1C675P0
D1_ENTITY_GRP_CHAR
D1C670P0
D1_ENTITY_GRP_CRIT
D1C671P0
D1C672P0
D1_ENTITY_GRP_L
D1C669P0
D1T639P0
D1T639S2
D1T639S3
D1T652S1
D1T641P0
D1T641S1
D1T640P0
D1T642P0
D1T643P0
D1_FACILITY_SP
D1T633P0
D1_IMD_CTRL_STAGE
D1T661P0
D1_IMD_CTRL_STAGE
D1T661S0
D1_IMD_CTRL_STAGE
D1T661S1
D1_IMD_CTRL_STAGE_K
D1T663P0
D1_IMD_TYPE
D1C664P0
D1_IMD_TYPE_ALG
D1C666P0
D1_IMD_TYPE_L
D1C665P0
D1_MSRMT_AUDIT
D1T662P0
D1_RULE
D1C649P0
D1_RULE_CHAR
D1C651P0
D1_RULE_L
D1C650P0
D1_RULE_PARM
D1C667P0
D1_SPR_PROG
D1C668P0
D1_SP_ENTITY_GRP
D1M673P0
D1_SP_ENTITY_GRP
D1M673S0
D1_SP_REL
D1M317S1
D1C637P0
D1_SP_TYPE_DIV
D1C635P0
D1M630P0
D1_USAGE_EXCP
D1T443S1
D1_US_QTY
D1M576P0
D1C644P0
D1C644S1
Added Columns
Table_Name
Column_Name
Data_Type
Data_Length
CI_ACC_GRP_ROLE
ACCESS_GRP_CD
CHAR
48
CI_ACC_GRP_ROLE
ROLE_ID
CHAR
40
CI_ACC_GRP_ROLE
TD_TYPE_CD
CHAR
32
CI_ACC_GRP_ROLE
VERSION
NUMBER
22
CI_ALG_PARM
ALG_PARM_VAL
VARCHAR2
32767
CI_BATCH_CTRL
BASE_BATCH_FLG
CHAR
16
CI_BATCH_CTRL
BATCH_TEMPLATE_XFLG
VARCHAR2
1016
CI_BATCH_CTRL_OPT
BATCH_CD
CHAR
32
CI_BATCH_CTRL_OPT
BATCH_CTRL_OPT_FLG
CHAR
16
CI_BATCH_CTRL_OPT
BATCH_CTRL_OPT_VAL
VARCHAR2
1016
CI_BATCH_CTRL_OPT
OWNER_FLG
CHAR
16
CI_BATCH_CTRL_OPT
SEQ_NUM
NUMBER
22
CI_BATCH_CTRL_OPT
VERSION
NUMBER
22
CI_BATCH_INST
END_DTTM
DATE
7
CI_BATCH_INST
FILE_DETAILS
CLOB
4000
CI_BATCH_INST
START_DTTM
DATE
7
CI_BATCH_JOB
SUBMIT_METH_FLG
CHAR
16
CI_BATCH_JOB
SUBMIT_USER_ID
CHAR
32
CI_BATCH_RUN
LOG_FILE_NAME
VARCHAR2
1016
CI_CHAR_TYPE
FLD_NAME
CHAR
120
CI_CNV_DUP_KEY
CX_ID
CHAR
120
CI_CNV_KEY_TMP
CI_ID
CHAR
120
CI_CNV_KEY_TMP
CX_ID
CHAR
120
CI_CNV_KEY_TMP
INIT_ID
VARCHAR2
120
CI_CURRENCY_CD
EXT_CURRENCY_CD
CHAR
144
CI_MD_FLD_ADDTL
FLD_NAME
CHAR
120
CI_MD_FLD_ADDTL
OWNER_FLG
CHAR
16
CI_MD_FLD_ADDTL
PII_CLASS_FLG
CHAR
16
CI_MD_FLD_ADDTL
VERSION
NUMBER
22
CI_MD_FLD_L
CONTEXT_LABEL1
VARCHAR2
240
CI_MD_FLD_L
CONTEXT_LABEL2
VARCHAR2
240
CI_MD_FLD_L
CONTEXT_LABEL3
VARCHAR2
240
CI_MD_FLD_L
CONTEXT_LABEL_TYPE1
CHAR
16
CI_MD_FLD_L
CONTEXT_LABEL_TYPE2
CHAR
16
CI_MD_FLD_L
CONTEXT_LABEL_TYPE3
CHAR
16
CI_MD_FLD_L
OVRD_CONTEXT_LABEL1
VARCHAR2
240
CI_MD_FLD_L
OVRD_CONTEXT_LABEL2
VARCHAR2
240
CI_MD_FLD_L
OVRD_CONTEXT_LABEL3
VARCHAR2
240
CI_MD_IDX
IDX_CD
VARCHAR2
512
CI_MD_IDX
OWNER_FLG
CHAR
16
CI_MD_IDX
TBL_NAME
CHAR
120
CI_MD_IDX
UNIQUE_SW
CHAR
4
CI_MD_IDX
VERSION
NUMBER
22
CI_MD_IDX_FLD
FLD_NAME
CHAR
120
CI_MD_IDX_FLD
IDX_CD
VARCHAR2
512
CI_MD_IDX_FLD
OWNER_FLG
CHAR
16
CI_MD_IDX_FLD
SEQ_NUM
NUMBER
22
CI_MD_IDX_FLD
VERSION
NUMBER
22
CI_MD_TBL
KEY_PREFIX_FLD_NAME
CHAR
120
CI_MD_TBL_ADDTL
OWNER_FLG
CHAR
16
CI_MD_TBL_ADDTL
TBL_GEN_STATUS_FLG
CHAR
16
CI_MD_TBL_ADDTL
TBL_NAME
CHAR
120
CI_MD_TBL_ADDTL
VERSION
NUMBER
22
CI_NT_XID
OWNER_FLG
CHAR
16
CI_NT_XID_L
OWNER_FLG
CHAR
16
CI_PORTAL
PORTAL_ROLE_FLG
CHAR
16
CI_PORTAL_ZONE
ZONE_HEIGHT_FLG
CHAR
16
CI_PORTAL_ZONE
ZONE_LAYOUT
CHAR
16
CI_PORTAL_ZONE
ZONE_MAX_HEIGHT_PCT
NUMBER
22
CI_PORTAL_ZONE
ZONE_ROWS
CHAR
16
CI_PORTAL_ZONE
ZONE_WIDTH_FLG
CHAR
16
CI_TD_ENTRY
RTE_BATCH_CD
CHAR
32
CI_TD_ENTRY
RTE_BATCH_NBR
NUMBER
22
CI_TD_ENTRY
TD_SUB_STATUS_FLG
CHAR
16
CI_TD_ENTRY_OPEN_VW
DKSQ1
NUMBER
22
CI_TD_ENTRY_OPEN_VW
DKSQ2
NUMBER
22
CI_TD_ENTRY_OPEN_VW
DKSQ3
NUMBER
22
CI_TD_ENTRY_OPEN_VW
DKSQ4
NUMBER
22
CI_TD_ENTRY_OPEN_VW
DKSQ5
NUMBER
22
CI_TD_ENTRY_OPEN_VW
SKSQ1
NUMBER
22
CI_TD_ENTRY_OPEN_VW
SKSQ2
NUMBER
22
CI_TD_ENTRY_OPEN_VW
SKSQ3
NUMBER
22
CI_TD_ENTRY_OPEN_VW
SKSQ4
NUMBER
22
CI_TD_ENTRY_OPEN_VW
SKSQ5
NUMBER
22
CI_TD_ENTRY_OPEN_VW
TD_SUB_STATUS_FLG
CHAR
16
CI_TD_LOG
TD_LOG_STATUS_FLG
CHAR
16
CI_XAI_SENDER
OWNER_FLG
CHAR
16
CI_XAI_SENDER_L
OWNER_FLG
CHAR
16
CI_XAI_SNDR_CTX
OWNER_FLG
CHAR
16
CI_ZONE
ZONE_ROLE_FLG
CHAR
16
CI_ZONE_PRM
ZONE_PARM_VAL
VARCHAR2
32767
D1_ACTIVITY
RESCHEDULE_REASON
VARCHAR2
1016
D1_ACTIVITY_ADJ_TYPE
D1_SP_TYPE_CD
VARCHAR2
120
D1_ACTIVITY_TYPE
SP_DVC_COND_SRC_FLG
CHAR
16
D1_ACTIVITY_TYPE
THROTTLE_OPT_FLG
CHAR
16
ACTIVITY_TYPE_CD
VARCHAR2
120
DIVISION_CD
VARCHAR2
120
VERSION
NUMBER
22
ACTIVITY_BO_TO_CREATE
CHAR
120
ACTIVITY_TYPE_CD
VARCHAR2
120
ALTERNATE_FIELD_TASK_TYPE
VARCHAR2
1016
BO_DATA_AREA
CLOB
4000
D1_SP_TYPE_CD
VARCHAR2
120
DEVICE_INSTALLED_AT_SP_SW
CHAR
4
DISCONN_LOC_FLG
CHAR
16
EXEC_OVRD_ALG_SW
CHAR
4
FIELD_TASK_TYPE
VARCHAR2
1016
INSTALL_EVENT_STATUS_OVERRIDE
VARCHAR2
1016
SEQNO
NUMBER
22
SP_CATEGORY_FLG
CHAR
16
SP_CONNECTED_SW
CHAR
4
SP_DVC_COND_FLG
CHAR
16
VERSION
NUMBER
22
D1_ACT_DVC_SP_VW
ACCESS_GRP_CD
CHAR
48
D1_ACT_DVC_SP_VW
D1_ACTIVITY_ID
CHAR
56
D1_ACT_DVC_SP_VW
D1_PK_VALUE
VARCHAR2
1016
D1_ACT_DVC_SP_VW
MAINT_OBJ_CD
CHAR
48
D1_AGG_GROUP_RUN_MC_SET
SCAN_BATCH_CD
CHAR
32
SCAN_BATCH_NBR
NUMBER
22
SCAN_BATCH_RERUN_NBR
NUMBER
22
D1_BI_DYN_AGG_VW
AGG_ATTR1
VARCHAR2
16000
D1_BI_DYN_AGG_VW
AGG_ATTR10
VARCHAR2
16000
D1_BI_DYN_AGG_VW
AGG_ATTR11
VARCHAR2
16000
D1_BI_DYN_AGG_VW
AGG_ATTR12
VARCHAR2
16000
D1_BI_DYN_AGG_VW
AGG_ATTR13
VARCHAR2
16000
D1_BI_DYN_AGG_VW
AGG_ATTR14
VARCHAR2
16000
D1_BI_DYN_AGG_VW
AGG_ATTR15
VARCHAR2
16000
D1_BI_DYN_AGG_VW
AGG_ATTR16
VARCHAR2
16000
D1_BI_DYN_AGG_VW
AGG_ATTR17
VARCHAR2
16000
D1_BI_DYN_AGG_VW
AGG_ATTR18
VARCHAR2
16000
D1_BI_DYN_AGG_VW
AGG_ATTR19
VARCHAR2
16000
D1_BI_DYN_AGG_VW
AGG_ATTR2
VARCHAR2
16000
D1_BI_DYN_AGG_VW
AGG_ATTR20
VARCHAR2
16000
D1_BI_DYN_AGG_VW
AGG_ATTR3
VARCHAR2
16000
D1_BI_DYN_AGG_VW
AGG_ATTR4
VARCHAR2
16000
D1_BI_DYN_AGG_VW
AGG_ATTR5
VARCHAR2
16000
D1_BI_DYN_AGG_VW
AGG_ATTR6
VARCHAR2
16000
D1_BI_DYN_AGG_VW
AGG_ATTR7
VARCHAR2
16000
D1_BI_DYN_AGG_VW
AGG_ATTR8
VARCHAR2
16000
D1_BI_DYN_AGG_VW
AGG_ATTR9
VARCHAR2
16000
D1_BI_DYN_AGG_VW
AGG_MEASR_COMP_ID
CHAR
48
D1_BI_DYN_AGG_VW
AGG_VAL
NUMBER
22
D1_BI_DYN_AGG_VW
AGG_VAL1
NUMBER
22
D1_BI_DYN_AGG_VW
AGG_VAL10
NUMBER
22
D1_BI_DYN_AGG_VW
AGG_VAL2
NUMBER
22
D1_BI_DYN_AGG_VW
AGG_VAL3
NUMBER
22
D1_BI_DYN_AGG_VW
AGG_VAL4
NUMBER
22
D1_BI_DYN_AGG_VW
AGG_VAL5
NUMBER
22
D1_BI_DYN_AGG_VW
AGG_VAL6
NUMBER
22
D1_BI_DYN_AGG_VW
AGG_VAL7
NUMBER
22
D1_BI_DYN_AGG_VW
AGG_VAL8
NUMBER
22
D1_BI_DYN_AGG_VW
AGG_VAL9
NUMBER
22
D1_BI_DYN_AGG_VW
MEASR_COMP_SET_CD
VARCHAR2
120
D1_BI_DYN_AGG_VW
MSRMT_DTTM
DATE
7
D1_CONS_EXT_TYPE
INTERVAL_SCALAR_FLG
CHAR
16
D1_CONTACT
ADDRESS1
VARCHAR2
1016
D1_CONTACT
ADDRESS1_UPPER
VARCHAR2
1016
D1_CONTACT
ADDRESS2
VARCHAR2
1016
D1_CONTACT
ADDRESS3
VARCHAR2
1016
D1_CONTACT
ADDRESS4
VARCHAR2
1016
D1_CONTACT
CITY
VARCHAR2
360
D1_CONTACT
CITY_UPPER
VARCHAR2
360
D1_CONTACT
COUNTRY
CHAR
12
D1_CONTACT
COUNTY
VARCHAR2
360
D1_CONTACT
GEO_CODE
CHAR
44
D1_CONTACT
HOUSE_TYPE
CHAR
8
D1_CONTACT
IN_CITY_LIMIT
CHAR
4
D1_CONTACT
NUM1
CHAR
24
D1_CONTACT
NUM2
CHAR
16
D1_CONTACT
POSTAL
CHAR
48
D1_CONTACT
STATE
CHAR
24
D1_CONTACT_COMM
BO_DATA_AREA
CLOB
4000
D1_CONTACT_COMM
BO_STATUS_CD
CHAR
48
D1_CONTACT_COMM
BUS_OBJ_CD
CHAR
120
D1_CONTACT_COMM
CONTACT_COMM_CAT
VARCHAR2
1016
D1_CONTACT_COMM
CONTACT_COMM_CHANNEL
VARCHAR2
1016
D1_CONTACT_COMM
CONTACT_COMM_CLASS
VARCHAR2
1016
D1_CONTACT_COMM
CONTACT_COMM_ID
CHAR
56
D1_CONTACT_COMM
CONTACT_COMM_NOTES
VARCHAR2
16000
D1_CONTACT_COMM
CONTACT_ID
CHAR
48
D1_CONTACT_COMM
CRE_DTTM
DATE
7
D1_CONTACT_COMM
D1_SP_ID
CHAR
48
D1_CONTACT_COMM
ILM_ARCH_SW
CHAR
4
D1_CONTACT_COMM
ILM_DT
DATE
7
D1_CONTACT_COMM
UPD_DTTM
DATE
7
D1_CONTACT_COMM
US_ID
CHAR
48
D1_CONTACT_COMM
VERSION
NUMBER
22
ADHOC_CHAR_VAL
VARCHAR2
1016
CHAR_TYPE_CD
CHAR
32
CHAR_VAL
CHAR
64
CHAR_VAL_FK1
VARCHAR2
200
CHAR_VAL_FK2
VARCHAR2
200
CHAR_VAL_FK3
VARCHAR2
200
CHAR_VAL_FK4
VARCHAR2
200
CHAR_VAL_FK5
VARCHAR2
200
CONTACT_COMM_ID
CHAR
56
SEQ_NUM
NUMBER
22
SRCH_CHAR_VAL
VARCHAR2
200
VERSION
NUMBER
22
D1_CONTACT_COMM_K
CONTACT_COMM_ID
CHAR
56
D1_CONTACT_COMM_K
ENV_ID
NUMBER
22
D1_CONTACT_COMM_LOG
ADHOC_CHAR_VAL
VARCHAR2
1016
D1_CONTACT_COMM_LOG
BO_STATUS_CD
CHAR
48
D1_CONTACT_COMM_LOG
BO_STATUS_REASON_CD
VARCHAR2
120
D1_CONTACT_COMM_LOG
CHAR_TYPE_CD
CHAR
32
D1_CONTACT_COMM_LOG
CHAR_VAL
CHAR
64
D1_CONTACT_COMM_LOG
CHAR_VAL_FK1
VARCHAR2
200
D1_CONTACT_COMM_LOG
CHAR_VAL_FK2
VARCHAR2
200
D1_CONTACT_COMM_LOG
CHAR_VAL_FK3
VARCHAR2
200
D1_CONTACT_COMM_LOG
CHAR_VAL_FK4
VARCHAR2
200
D1_CONTACT_COMM_LOG
CHAR_VAL_FK5
VARCHAR2
200
D1_CONTACT_COMM_LOG
CONTACT_COMM_ID
CHAR
56
D1_CONTACT_COMM_LOG
DESCRLONG
VARCHAR2
16000
D1_CONTACT_COMM_LOG
LOG_DTTM
DATE
7
D1_CONTACT_COMM_LOG
LOG_ENTRY_TYPE_FLG
CHAR
16
D1_CONTACT_COMM_LOG
MESSAGE_CAT_NBR
NUMBER
22
D1_CONTACT_COMM_LOG
MESSAGE_NBR
NUMBER
22
D1_CONTACT_COMM_LOG
SEQNO
NUMBER
22
D1_CONTACT_COMM_LOG
USER_ID
CHAR
32
D1_CONTACT_COMM_LOG
VERSION
NUMBER
22
CONTACT_COMM_ID
CHAR
56
MSG_PARM_TYP_FLG
CHAR
16
MSG_PARM_VAL
VARCHAR2
8000
PARM_SEQ
NUMBER
22
SEQNO
NUMBER
22
VERSION
NUMBER
22
CONTACT_COMM_ID
CHAR
56
MAINT_OBJ_CD
CHAR
48
PK_VALUE1
VARCHAR2
1016
PK_VALUE2
VARCHAR2
1016
PK_VALUE3
VARCHAR2
1016
PK_VALUE4
VARCHAR2
1016
PK_VALUE5
VARCHAR2
1016
SEQNO
NUMBER
22
VERSION
NUMBER
22
D1_CONTACT_EMAIL
EMAIL_VALUE
VARCHAR2
1016
D1_CONTACT_TYPE
CONTACT_USE_FLG
CHAR
16
D1_DVC
ACCESS_GRP_CD
CHAR
48
D1_DVC
DER_AGG_SPR_CD
VARCHAR2
120
D1_DVC_ENTITY_GRP
BO_DATA_AREA
CLOB
4000
D1_DVC_ENTITY_GRP
D1_DEVICE_ID
CHAR
48
D1_DVC_ENTITY_GRP
EFF_DTTM
DATE
7
D1_DVC_ENTITY_GRP
ENTITY_GRP_CD
VARCHAR2
120
D1_DVC_ENTITY_GRP
EXPIRATION_DTTM
DATE
7
D1_DVC_ENTITY_GRP
VERSION
NUMBER
22
D1_DVC_EQPMNT
BO_DATA_AREA
CLOB
4000
D1_DVC_EQPMNT
COMMENTS
VARCHAR2
1016
D1_DVC_EQPMNT
D1_DEVICE_ID
CHAR
48
D1_DVC_EQPMNT
D1_EQPMNT_ID
CHAR
48
D1_DVC_EQPMNT
D1_INSTALL_DTTM
DATE
7
D1_DVC_EQPMNT
D1_REMOVAL_DTTM
DATE
7
D1_DVC_EQPMNT
EQPMNT_CNT
NUMBER
22
D1_DVC_EQPMNT
MEASR_COMP_ID
CHAR
48
D1_DVC_EQPMNT
VERSION
NUMBER
22
D1_DVC_SP_VW
DIVISION_CD
VARCHAR2
120
D1_DVC_TYPE
ATTACHED_TO_FLG
CHAR
16
ADHOC_CHAR_VAL
VARCHAR2
1016
CHAR_TYPE_CD
CHAR
32
CHAR_VAL
CHAR
64
CHAR_VAL_FK1
VARCHAR2
200
CHAR_VAL_FK2
VARCHAR2
200
CHAR_VAL_FK3
VARCHAR2
200
CHAR_VAL_FK4
VARCHAR2
200
CHAR_VAL_FK5
VARCHAR2
200
DEFAULT_SW
CHAR
4
DEVICE_TYPE_CD
VARCHAR2
120
REQUIRED_SW
CHAR
4
SORT_SEQ
NUMBER
22
VERSION
NUMBER
22
D1_DYN_OPT
D1_APPROVAL_PROF_CD
VARCHAR2
120
D1_DYN_OPT
D1_INITIATIVE_CD
VARCHAR2
120
D1_DYN_OPT
DIVISION_CD
VARCHAR2
120
D1_DYN_OPT
END_DT
DATE
7
D1_DYN_OPT
EXT_DYN_OPT_ID_VALUE
VARCHAR2
480
D1_DYN_OPT
START_DT
DATE
7
D1_DYN_OPT
SUSPEND_FLG
CHAR
16
D1_DYN_OPT_EVENT
DYN_OPT_EVENT_CAT_FLG
CHAR
16
D1_DYN_OPT_EVENT
DYN_OPT_EXT_EVT_ID_VALUE
VARCHAR2
480
D1_DYN_OPT_EVENT
DYN_OPT_EXT_ID_VALUE
VARCHAR2
480
D1_DYN_OPT_QTY
DYN_OPT_ID
CHAR
48
D1_DYN_OPT_QTY
DYN_OPT_QTY
NUMBER
22
D1_DYN_OPT_QTY
DYN_OPT_QTY_TYPE
VARCHAR2
1016
D1_DYN_OPT_QTY
END_DTTM
DATE
7
D1_DYN_OPT_QTY
START_DTTM
DATE
7
D1_DYN_OPT_QTY
VERSION
NUMBER
22
D1_DYN_OPT_QUESTION
D1_ANSWER_CD
VARCHAR2
120
D1_DYN_OPT_QUESTION
D1_QUESTION_CD
VARCHAR2
120
D1_DYN_OPT_QUESTION
DYN_OPT_ID
CHAR
48
D1_DYN_OPT_QUESTION
QUESTION_CATEGORY
VARCHAR2
1016
D1_DYN_OPT_QUESTION
RESPONSE_REQ_FLG
CHAR
16
D1_DYN_OPT_QUESTION
SEQNO
NUMBER
22
D1_DYN_OPT_QUESTION
VERSION
NUMBER
22
D1_DYN_OPT_RATE
D1_RS_CD
VARCHAR2
1016
D1_DYN_OPT_RATE
DYN_OPT_ID
CHAR
48
D1_DYN_OPT_RATE
SEQNO
NUMBER
22
D1_DYN_OPT_RATE
VERSION
NUMBER
22
D1_DYN_OPT_RULE
CHAR
16
D1_DYN_OPT_RULE
DYN_OPT_ID
CHAR
48
D1_DYN_OPT_RULE
DYN_OPT_RULE_CD
VARCHAR2
120
D1_DYN_OPT_RULE
SEQNO
NUMBER
22
D1_DYN_OPT_RULE
VERSION
NUMBER
22
D1_SPECIFICATION_CD
VARCHAR2
120
DYN_OPT_ID
CHAR
48
SEQNO
NUMBER
22
VERSION
NUMBER
22
D1_DYN_OPT_TYPE
D1_APPROVAL_PROF_CD
VARCHAR2
120
D1_DYN_OPT_TYPE
DEVICE_REQD_FLG
CHAR
16
D1_DYN_OPT_TYPE
DYN_OPT_CATEGORY
VARCHAR2
1016
D1_DYN_OPT_TYPE
DYN_OPT_EVENT_BO_CD
CHAR
120
D1_DYN_OPT_TYPE
EVENT_PARTICIPATION_BO_CD
CHAR
120
D1_DYN_OPT_TYPE
LOCATION_REQD_SOURCE_FLG
CHAR
16
DYN_OPT_TYPE_CD
VARCHAR2
120
VARCHAR2
1016
VERSION
NUMBER
22
D1_DYN_OPT_TYPE_REL
DYN_OPT_TYPE_CD
VARCHAR2
120
D1_DYN_OPT_TYPE_REL
DYN_OPT_TYPE_REL_TYPE_CD
VARCHAR2
120
D1_DYN_OPT_TYPE_REL
SEQNO
NUMBER
22
D1_DYN_OPT_TYPE_REL
VERSION
NUMBER
22
D1_DYN_OPT_USG_GRP
CALC_GRP_CATEGORY_FLG
CHAR
16
D1_DYN_OPT_USG_GRP
DYN_OPT_ID
CHAR
48
D1_DYN_OPT_USG_GRP
EFF_DTTM
DATE
7
D1_DYN_OPT_USG_GRP
EXPIRATION_DTTM
DATE
7
D1_DYN_OPT_USG_GRP
USG_GRP_CD
VARCHAR2
120
D1_DYN_OPT_USG_GRP
VERSION
NUMBER
22
D1_ENTITY_GRP
BO_DATA_AREA
CLOB
4000
D1_ENTITY_GRP
BUS_OBJ_CD
CHAR
120
D1_ENTITY_GRP
ENTITY_GRP_ASSGN_OPT_FLG
CHAR
16
D1_ENTITY_GRP
ENTITY_GRP_CATEGORY
VARCHAR2
1016
D1_ENTITY_GRP
ENTITY_GRP_CD
VARCHAR2
120
D1_ENTITY_GRP
ENTITY_GRP_DEACT_OPT_FLG
CHAR
16
D1_ENTITY_GRP
ENTITY_GRP_STAT_FLG
CHAR
16
D1_ENTITY_GRP
VERSION
NUMBER
22
D1_ENTITY_GRP_CHAR
ADHOC_CHAR_VAL
VARCHAR2
1016
D1_ENTITY_GRP_CHAR
CHAR_TYPE_CD
CHAR
32
D1_ENTITY_GRP_CHAR
CHAR_VAL
CHAR
64
D1_ENTITY_GRP_CHAR
CHAR_VAL_FK1
VARCHAR2
200
D1_ENTITY_GRP_CHAR
CHAR_VAL_FK2
VARCHAR2
200
D1_ENTITY_GRP_CHAR
CHAR_VAL_FK3
VARCHAR2
200
D1_ENTITY_GRP_CHAR
CHAR_VAL_FK4
VARCHAR2
200
D1_ENTITY_GRP_CHAR
CHAR_VAL_FK5
VARCHAR2
200
D1_ENTITY_GRP_CHAR
ENTITY_GRP_CD
VARCHAR2
120
D1_ENTITY_GRP_CHAR
SEQ_NUM
NUMBER
22
D1_ENTITY_GRP_CHAR
SRCH_CHAR_VAL
VARCHAR2
200
D1_ENTITY_GRP_CHAR
VERSION
NUMBER
22
D1_ENTITY_GRP_CRIT
CRITERIA_SEQ_NUM
NUMBER
22
D1_ENTITY_GRP_CRIT
ENTITY_GRP_CD
VARCHAR2
120
D1_ENTITY_GRP_CRIT
GRP_CRITERIA_SRC
VARCHAR2
1016
D1_ENTITY_GRP_CRIT
VERSION
NUMBER
22
BO_DATA_AREA
CLOB
4000
CRITERIA_SEQ_NUM
NUMBER
22
CRITERIA_VALUE
CHAR
200
CRITERIA_VAL_SEQ_NUM
NUMBER
22
ENTITY_GRP_CD
VARCHAR2
120
GRP_CRITERIA_SRC
VARCHAR2
1016
VERSION
NUMBER
22
D1_ENTITY_GRP_L
DESCR100
VARCHAR2
400
D1_ENTITY_GRP_L
DESCRLONG
VARCHAR2
16000
D1_ENTITY_GRP_L
ENTITY_GRP_CD
VARCHAR2
120
D1_ENTITY_GRP_L
LANGUAGE_CD
CHAR
12
D1_ENTITY_GRP_L
VERSION
NUMBER
22
BO_STATUS_CD
CHAR
48
BO_STATUS_REASON_CD
VARCHAR2
120
BO_XML_DATA_AREA
XMLTYPE
2000
BUS_OBJ_CD
CHAR
120
CRE_DTTM
DATE
7
D1_DEVICE_ID
CHAR
48
DYN_OPT_EVENT_ID
CHAR
56
DYN_OPT_ID
CHAR
48
EVENT_PARTICIPATION_ID
CHAR
56
ILM_ARCH_SW
CHAR
4
ILM_DT
DATE
7
OUTCOME_FLG
CHAR
16
PARTICIPATION_END_DTTM
DATE
7
PARTICIPATION_START_DTTM
DATE
7
PREEMPTIVE_OPT_OUT_FLG
CHAR
16
RESERVATION_END_DTTM
DATE
7
RESERVATION_FLG
CHAR
16
RESERVATION_START_DTTM
DATE
7
STATUS_UPD_DTTM
DATE
7
US_ID
CHAR
48
VERSION
NUMBER
22
ADHOC_CHAR_VAL
VARCHAR2
1016
CHAR_TYPE_CD
CHAR
32
CHAR_VAL
CHAR
64
CHAR_VAL_FK1
VARCHAR2
200
CHAR_VAL_FK2
VARCHAR2
200
CHAR_VAL_FK3
VARCHAR2
200
CHAR_VAL_FK4
VARCHAR2
200
CHAR_VAL_FK5
VARCHAR2
200
VARCHAR2
56
SEQ_NUM
NUMBER
22
SRCH_CHAR_VAL
VARCHAR2
200
VERSION
NUMBER
22
ENV_ID
NUMBER
22
CHAR
56
ADHOC_CHAR_VAL
VARCHAR2
1016
BO_STATUS_CD
CHAR
48
BO_STATUS_REASON_CD
VARCHAR2
120
CHAR_TYPE_CD
CHAR
32
CHAR_VAL
CHAR
64
CHAR_VAL_FK1
VARCHAR2
200
CHAR_VAL_FK2
VARCHAR2
200
CHAR_VAL_FK3
VARCHAR2
200
CHAR_VAL_FK4
VARCHAR2
200
CHAR_VAL_FK5
VARCHAR2
200
DESCRLONG
VARCHAR2
16000
CHAR
56
LOG_DTTM
DATE
7
LOG_ENTRY_TYPE_FLG
CHAR
16
MESSAGE_CAT_NBR
NUMBER
22
MESSAGE_NBR
NUMBER
22
SEQNO
NUMBER
22
USER_ID
CHAR
32
VERSION
NUMBER
22
CHAR
56
MSG_PARM_TYP_FLG
CHAR
16
MSG_PARM_VAL
VARCHAR2
8000
PARM_SEQ
NUMBER
22
SEQNO
NUMBER
22
VERSION
NUMBER
22
D1_FACILITY_SP
D1_SP_ID
CHAR
48
D1_FACILITY_SP
FACILITY_ID
CHAR
56
D1_FACILITY_SP
VERSION
NUMBER
22
D1_IMD_CTRL_STAGE
ALG_CD
CHAR
48
D1_IMD_CTRL_STAGE
D1_FROM_DTTM
DATE
7
D1_IMD_CTRL_STAGE
D1_TO_DTTM
DATE
7
D1_IMD_CTRL_STAGE
IMD_CTRL_DC_ID
CHAR
48
D1_IMD_CTRL_STAGE
IMD_CTRL_MC_ID
CHAR
48
D1_IMD_CTRL_STAGE
IMD_CTRL_STAGE_ID
CHAR
56
D1_IMD_CTRL_STAGE
IMD_STAGE_PAYLOAD_XML
CLOB
4000
D1_IMD_CTRL_STAGE
IMD_STAGE_STATUS_FLG
CHAR
16
D1_IMD_CTRL_STAGE
IMD_TYPE_CD
VARCHAR2
120
D1_IMD_CTRL_STAGE_K
ENV_ID
NUMBER
22
D1_IMD_CTRL_STAGE_K
IMD_CTRL_STAGE_ID
CHAR
56
D1_IMD_TYPE
BO_DATA_AREA
CLOB
4000
D1_IMD_TYPE
BUS_OBJ_CD
CHAR
120
D1_IMD_TYPE
IMD_BUS_OBJ_CD
CHAR
120
D1_IMD_TYPE
IMD_SEEDER_FLG
CHAR
16
D1_IMD_TYPE
IMD_TYPE_CD
VARCHAR2
120
D1_IMD_TYPE
IMD_TYPE_STATUS_FLG
CHAR
16
D1_IMD_TYPE
OWNER_FLG
CHAR
16
D1_IMD_TYPE
VERSION
NUMBER
22
D1_IMD_TYPE_ALG
ALG_CD
CHAR
48
D1_IMD_TYPE_ALG
ERROR_BO_STATUS_CD
CHAR
48
D1_IMD_TYPE_ALG
IMD_TYPE_ALG_STATUS_FLG
CHAR
16
D1_IMD_TYPE_ALG
IMD_TYPE_CD
VARCHAR2
120
D1_IMD_TYPE_ALG
IMD_TYPE_SEVT_FLG
CHAR
16
D1_IMD_TYPE_ALG
OWNER_FLG
CHAR
16
D1_IMD_TYPE_ALG
SEQ_NUM
NUMBER
22
D1_IMD_TYPE_ALG
VERSION
NUMBER
22
D1_IMD_TYPE_L
DESCR100
VARCHAR2
400
D1_IMD_TYPE_L
DESCRLONG
VARCHAR2
16000
D1_IMD_TYPE_L
IMD_TYPE_CD
VARCHAR2
120
D1_IMD_TYPE_L
LANGUAGE_CD
CHAR
12
D1_IMD_TYPE_L
OWNER_FLG
CHAR
16
D1_IMD_TYPE_L
VERSION
NUMBER
22
D1_INBOUND_COMM_VW
D1_SP_ID
CHAR
48
D1_INBOUND_COMM_VW
DIVISION_CD
VARCHAR2
120
D1_INBOUND_COMM_VW
POSTAL
CHAR
48
CUT_OFF_TIME
VARCHAR2
32767
EVALUATION_DTTM
DATE
7
HRS_WAIT_BEFORE_EST
NUMBER
22
INTERVAL_SCALAR_FLG
CHAR
16
MC_CLASS_FLG
CHAR
16
MEASR_COMP_TYPE_CD
VARCHAR2
120
TIME_ZONE_CD
CHAR
40
D1_MDSI
VERSION
NUMBER
22
D1_MDSS
VERSION
NUMBER
22
D1_MEASR_COMP
ACCESS_GRP_CD
CHAR
48
D1_MEASR_COMP_SET
DISTRIBUTE_LOAD_FLG
CHAR
16
D1_MEASR_COMP_SET
LOAD_DISTRIBUTION_FORMULA
VARCHAR2
1016
D1_MEASR_COMP_SET
LOAD_DIST_MANAGED_BY_FLG
CHAR
16
D1_MEASR_COMP_SET
NBR_OF_DIGITS_TO_USE
NUMBER
22
D1_MEASR_COMP_TYPE
ANCHR_TIME
DATE
7
D1_MEASR_COMP_TYPE
IMD_HANDLING_FLG
CHAR
16
D1_MSRMT
PREVEE_MSRMT_COND_FLG
CHAR
24
D1_MSRMT
PREVEE_MSRMT_VAL
NUMBER
22
D1_MSRMT
PREVEE_READING_COND_FLG
CHAR
24
D1_MSRMT
PREVEE_READING_VAL
NUMBER
22
D1_MSRMT
USER_ID
CHAR
32
D1_MSRMT_AUDIT
AFTER_COMBINED_MULTIPLIER
NUMBER
22
D1_MSRMT_AUDIT
AFTER_MSRMT_COND_FLG
CHAR
24
D1_MSRMT_AUDIT
AFTER_MSRMT_USE_FLG
CHAR
16
D1_MSRMT_AUDIT
AFTER_MSRMT_VAL
NUMBER
22
D1_MSRMT_AUDIT
AFTER_PREVEE_MSRMT_COND_FLG
CHAR
24
D1_MSRMT_AUDIT
AFTER_PREVEE_MSRMT_VAL
NUMBER
22
D1_MSRMT_AUDIT
AFTER_PREVEE_READING_COND_FLG
CHAR
24
D1_MSRMT_AUDIT
AFTER_PREVEE_READING_VAL
NUMBER
22
D1_MSRMT_AUDIT
AFTER_PREV_MSRMT_DTTM
DATE
7
D1_MSRMT_AUDIT
AFTER_READING_COND_FLG
CHAR
24
D1_MSRMT_AUDIT
AFTER_READING_VAL
NUMBER
22
D1_MSRMT_AUDIT
BEFORE_COMBINED_MULTIPLIER
NUMBER
22
D1_MSRMT_AUDIT
BEFORE_MSRMT_COND_FLG
CHAR
24
D1_MSRMT_AUDIT
BEFORE_MSRMT_USE_FLG
CHAR
16
D1_MSRMT_AUDIT
BEFORE_MSRMT_VAL
NUMBER
22
D1_MSRMT_AUDIT
BEFORE_PREVEE_MSRMT_COND_FLG
CHAR
24
D1_MSRMT_AUDIT
BEFORE_PREVEE_MSRMT_VAL
NUMBER
22
D1_MSRMT_AUDIT
BEFORE_PREVEE_READING_COND_FLG
CHAR
24
D1_MSRMT_AUDIT
BEFORE_PREVEE_READING_VAL
NUMBER
22
D1_MSRMT_AUDIT
BEFORE_PREV_MSRMT_DTTM
DATE
7
D1_MSRMT_AUDIT
BEFORE_READING_COND_FLG
CHAR
24
D1_MSRMT_AUDIT
BEFORE_READING_VAL
NUMBER
22
D1_MSRMT_AUDIT
LOG_DTTM
DATE
7
D1_MSRMT_AUDIT
MEASR_COMP_ID
CHAR
48
D1_MSRMT_AUDIT
MSRMT_AUDIT_ENTRY_TYPE_FLG
CHAR
16
D1_MSRMT_AUDIT
MSRMT_DTTM
DATE
7
D1_MSRMT_AUDIT
SEQNO
NUMBER
22
D1_MSRMT_AUDIT
USER_ID
CHAR
32
D1_NW_LOC
NETWORK_NODE_1
CHAR
56
D1_NW_LOC
NETWORK_NODE_2
CHAR
56
D1_ON_DOE_VW
ADHOC_CHAR_VAL
VARCHAR2
1016
D1_ON_DO_VW
ADHOC_CHAR_VAL
VARCHAR2
1016
D1_ON_DVC_CFG_VW
ADHOC_CHAR_VAL
VARCHAR2
1016
D1_ON_IE_VW
ADHOC_CHAR_VAL
VARCHAR2
1016
D1_OUTBOUND_COMM_VW
D1_SP_ID
CHAR
48
D1_OUTBOUND_COMM_VW
DIVISION_CD
VARCHAR2
120
D1_OUTBOUND_COMM_VW
POSTAL
CHAR
48
D1_RULE
BO_DATA_AREA
CLOB
4000
D1_RULE
BO_STATUS_CD
CHAR
48
D1_RULE
BUS_OBJ_CD
VARCHAR2
120
D1_RULE
EFF_DT
DATE
7
D1_RULE
EXPIRATION_DT
DATE
7
D1_RULE
RULE_CD
VARCHAR2
120
D1_RULE
RULE_TYPE_FLG
CHAR
16
D1_RULE
VERSION
NUMBER
22
D1_RULE_CHAR
ADHOC_CHAR_VAL
VARCHAR2
1016
D1_RULE_CHAR
CHAR_TYPE_CD
CHAR
32
D1_RULE_CHAR
CHAR_VAL
CHAR
64
D1_RULE_CHAR
CHAR_VAL_FK1
VARCHAR2
200
D1_RULE_CHAR
CHAR_VAL_FK2
VARCHAR2
200
D1_RULE_CHAR
CHAR_VAL_FK3
VARCHAR2
200
D1_RULE_CHAR
CHAR_VAL_FK4
VARCHAR2
200
D1_RULE_CHAR
CHAR_VAL_FK5
VARCHAR2
200
D1_RULE_CHAR
RULE_CD
VARCHAR2
120
D1_RULE_CHAR
SEQ_NUM
NUMBER
22
D1_RULE_CHAR
SRCH_CHAR_VAL
VARCHAR2
200
D1_RULE_CHAR
VERSION
NUMBER
22
D1_RULE_L
DESCR100
VARCHAR2
400
D1_RULE_L
DESCRLONG
VARCHAR2
16000
D1_RULE_L
LANGUAGE_CD
CHAR
12
D1_RULE_L
RULE_CD
VARCHAR2
120
D1_RULE_L
VERSION
NUMBER
22
D1_RULE_PARM
CALC_FREQUENCY
VARCHAR2
1016
D1_RULE_PARM
D1_SEASONAL_FLG
CHAR
16
D1_RULE_PARM
ELIG_ALG_CD
CHAR
48
D1_RULE_PARM
LINE_EXT_ID
VARCHAR2
1016
D1_RULE_PARM
MIN_DAYS
NUMBER
22
D1_RULE_PARM
PRORATE_OPTION_FLG
CHAR
16
D1_RULE_PARM
RULE_CD
VARCHAR2
120
D1_RULE_PARM
RULE_TYPE_CATEGORY
VARCHAR2
1016
D1_RULE_PARM
SEASON_END
CHAR
16
D1_RULE_PARM
SEASON_START
CHAR
16
D1_RULE_PARM
SEQNO
NUMBER
22
D1_RULE_PARM
SETT_FREQ_FLG
CHAR
16
D1_RULE_PARM
USG_GRP_CD
VARCHAR2
120
D1_RULE_PARM
VERSION
NUMBER
22
D1_SP
D1_ABOLISH_DT
DATE
7
D1_SP
D1_INSTALL_DT
DATE
7
D1_SP
D1_SERVICE_AREA_CD
VARCHAR2
120
D1_SPR
ACTIVE_INACTIVE_FLG
CHAR
16
D1_SPR
CONTACT_ID
CHAR
48
D1_SPR
END_DT
DATE
7
D1_SPR
START_DT
DATE
7
D1_SPR_PROG
D1_SPR_CD
VARCHAR2
120
D1_SPR_PROG
DYN_OPT_ID
CHAR
48
D1_SPR_PROG
END_DT
DATE
7
D1_SPR_PROG
SPR_LFDI
VARCHAR2
1016
D1_SPR_PROG
START_DT
DATE
7
D1_SPR_PROG
UTILITY_APPROVAL_REQD_FLG
CHAR
16
D1_SP_ENTITY_GRP
BO_DATA_AREA
CLOB
4000
D1_SP_ENTITY_GRP
D1_SP_ID
CHAR
48
D1_SP_ENTITY_GRP
EFF_DTTM
DATE
7
D1_SP_ENTITY_GRP
ENTITY_GRP_CD
VARCHAR2
120
D1_SP_ENTITY_GRP
EXPIRATION_DTTM
DATE
7
D1_SP_ENTITY_GRP
VERSION
NUMBER
22
D1_SP_EQPMNT
ACTIVE_INACTIVE_FLG
CHAR
16
D1_SP_EQPMNT
BO_DATA_AREA
CLOB
4000
D1_SP_EQPMNT
EQPMNT_CNT
NUMBER
22
D1_SP_EQPMNT
SEQNO
NUMBER
22
D1_SP_TYPE
SP_CLASS_FLG
CHAR
16
BO_DATA_AREA
CLOB
4000
D1_SP_TYPE_CD
VARCHAR2
120
DISCONN_LOC_FLG
CHAR
16
VERSION
NUMBER
22
D1_SP_TYPE_DIV
D1_SP_TYPE_CD
VARCHAR2
120
D1_SP_TYPE_DIV
DIVISION_CD
VARCHAR2
120
D1_SP_TYPE_DIV
VERSION
NUMBER
22
BO_DATA_AREA
CLOB
4000
D1_SP_TYPE_CD
VARCHAR2
120
FIELD_TASK_TYPE
VARCHAR2
1016
VERSION
NUMBER
22
D1_SVC_TYPE
STD_SVC_TYPE_FLG
CHAR
16
D1_US
PGM_ENRL_SRC_FLG
CHAR
16
D1_USAGE
EVT_SETT_REQ_TYPE_FLG
CHAR
16
D1_USAGE
EXTRACT_FLG
CHAR
16
D1_USAGE
RULE_CD
VARCHAR2
120
D1_USAGE
RULE_TYPE_CATEGORY
VARCHAR2
1016
D1_USAGE_PERIOD_SQ
D1_AMOUNT
NUMBER
22
D1_USAGE_PERIOD_SQ
D1_CURRENCY_CD
CHAR
12
D1_USAGE_PERIOD_SQ
D1_FORMULA
VARCHAR2
200
D1_USAGE_PERIOD_SQ
D1_PRICE
NUMBER
22
D1_USAGE_PERIOD_SQ
D1_QUANTITY1
NUMBER
22
D1_USAGE_PERIOD_SQ
D1_QUANTITY2
NUMBER
22
D1_USAGE_PERIOD_SQ
D1_QUANTITY3
NUMBER
22
D1_USAGE_PERIOD_SQ
D1_QUANTITY4
NUMBER
22
D1_USAGE_PERIOD_SQ
D1_QUANTITY5
NUMBER
22
D1_USAGE_PERIOD_SQ
D1_VARIABLE_NAME
CHAR
80
D1_USAGE_PERIOD_SQ
DYN_OPT_EVENT_ID
CHAR
56
D1_USAGE_PERIOD_SQ
DYN_OPT_ID
CHAR
48
D1_USAGE_PERIOD_SQ
LINE_DESCR
VARCHAR2
1016
D1_USAGE_PERIOD_SQ_DATA
D1_AMOUNT
NUMBER
22
D1_PRICE
NUMBER
22
D1_USG_RULE_L
LINE_DESCR
VARCHAR2
1016
D1_US_DYN_OPT
SEQNO
NUMBER
22
D1_US_SP
SEQNO
NUMBER
22
D1_US_TYPE
EVT_SETT_BO_CD
CHAR
120
D1_US_TYPE
PROC_TIMETABLE_TYPE_CD
VARCHAR2
120
ADHOC_CHAR_VAL
VARCHAR2
1016
CHAR_TYPE_CD
CHAR
32
CHAR_VAL
CHAR
64
CHAR_VAL_FK1
VARCHAR2
200
CHAR_VAL_FK2
VARCHAR2
200
CHAR_VAL_FK3
VARCHAR2
200
CHAR_VAL_FK4
VARCHAR2
200
CHAR_VAL_FK5
VARCHAR2
200
DEFAULT_SW
CHAR
4
REQUIRED_SW
CHAR
4
SORT_SEQ
NUMBER
22
US_TYPE_CD
VARCHAR2
120
VERSION
NUMBER
22
D2_MEASR_QTY_AGR_MV
LOCAL_DT
DATE
7
D2_MEASR_QTY_AGR_MV
MEASR_COMP_ID
CHAR
48
D2_MEASR_QTY_AGR_MV
MSRMT_DT
DATE
7
D2_MEASR_QTY_AGR_MV
MSRMT_DTTM
DATE
7
D2_MEASR_QTY_AGR_MV
MSRMT_LOCAL_DTTM
DATE
7
D2_MEASR_QTY_AGR_MV
MSRMT_VAL
NUMBER
22
D2_MEASR_QTY_AGR_MV
MSRMT_VAL1
NUMBER
22
D2_MEASR_QTY_AGR_MV
MSRMT_VAL10
NUMBER
22
D2_MEASR_QTY_AGR_MV
MSRMT_VAL2
NUMBER
22
D2_MEASR_QTY_AGR_MV
MSRMT_VAL3
NUMBER
22
D2_MEASR_QTY_AGR_MV
MSRMT_VAL4
NUMBER
22
D2_MEASR_QTY_AGR_MV
MSRMT_VAL5
NUMBER
22
D2_MEASR_QTY_AGR_MV
MSRMT_VAL6
NUMBER
22
D2_MEASR_QTY_AGR_MV
MSRMT_VAL7
NUMBER
22
D2_MEASR_QTY_AGR_MV
MSRMT_VAL8
NUMBER
22
D2_MEASR_QTY_AGR_MV
MSRMT_VAL9
NUMBER
22
D2_MEASR_QTY_MV
CITY
VARCHAR2
200
D2_MEASR_QTY_MV
D1_MODEL_CD
VARCHAR2
200
D2_MEASR_QTY_MV
D1_SPR_CD
VARCHAR2
200
D2_MEASR_QTY_MV
D1_SVC_TPE_CD
VARCHAR2
200
D2_MEASR_QTY_MV
DEVICE_TYPE_CD
VARCHAR2
200
D2_MEASR_QTY_MV
DEVICE_TYPE_DESCR
VARCHAR2
400
D2_MEASR_QTY_MV
GEO_CODE
VARCHAR2
200
D2_MEASR_QTY_MV
HEAD_END_SYSTEM_CD
VARCHAR2
200
D2_MEASR_QTY_MV
HEAD_END_SYSTEM_DESCR
VARCHAR2
400
D2_MEASR_QTY_MV
MANUFACTURER_CD
VARCHAR2
200
D2_MEASR_QTY_MV
MANUFACTURER_DESCR
VARCHAR2
400
D2_MEASR_QTY_MV
MC_TYPE_DESCR
VARCHAR2
400
D2_MEASR_QTY_MV
MEASR_COMP_ID
CHAR
48
D2_MEASR_QTY_MV
MEASR_COMP_TYPE_CD
VARCHAR2
120
D2_MEASR_QTY_MV
MKT_CD
VARCHAR2
200
D2_MEASR_QTY_MV
MKT_DESCR
VARCHAR2
400
D2_MEASR_QTY_MV
MKT_REL_TYPE_DESCR
VARCHAR2
240
D2_MEASR_QTY_MV
MKT_REL_TYPE_FLG
VARCHAR2
200
D2_MEASR_QTY_MV
MODEL_DESCR
VARCHAR2
400
D2_MEASR_QTY_MV
POSTAL
VARCHAR2
200
D2_MEASR_QTY_MV
SPR_DESCR
VARCHAR2
400
D2_MEASR_QTY_MV
SVC_TYPE_DESCR
VARCHAR2
400
D2_MEASR_QTY_MV
USG_CALC_GRP_CD
VARCHAR2
200
D2_MEASR_QTY_MV
USG_CALC_GRP_DESCR
VARCHAR2
400
LOCAL_DT
DATE
7
MEASR_COMP_ID
CHAR
48
MSRMT_DT
DATE
7
MSRMT_DTTM
DATE
7
MSRMT_LOCAL_DTTM
DATE
7
MSRMT_VAL
NUMBER
22
MSRMT_VAL1
NUMBER
22
MSRMT_VAL10
NUMBER
22
MSRMT_VAL2
NUMBER
22
MSRMT_VAL3
NUMBER
22
MSRMT_VAL4
NUMBER
22
MSRMT_VAL5
NUMBER
22
MSRMT_VAL6
NUMBER
22
MSRMT_VAL7
NUMBER
22
MSRMT_VAL8
NUMBER
22
MSRMT_VAL9
NUMBER
22
D2_QUALITY_CNT_MV
CITY
VARCHAR2
200
D2_QUALITY_CNT_MV
D1_MODEL_CD
VARCHAR2
200
D2_QUALITY_CNT_MV
D1_SPR_CD
VARCHAR2
200
D2_QUALITY_CNT_MV
D1_SVC_TPE_CD
VARCHAR2
200
D2_QUALITY_CNT_MV
DEVICE_TYPE_CD
VARCHAR2
200
D2_QUALITY_CNT_MV
DEVICE_TYPE_DESCR
VARCHAR2
400
D2_QUALITY_CNT_MV
GEO_CODE
VARCHAR2
200
D2_QUALITY_CNT_MV
HEAD_END_SYSTEM_CD
VARCHAR2
200
D2_QUALITY_CNT_MV
VARCHAR2
400
D2_QUALITY_CNT_MV
MANUFACTURER_CD
VARCHAR2
200
D2_QUALITY_CNT_MV
MANUFACTURER_DESCR
VARCHAR2
400
D2_QUALITY_CNT_MV
MC_TYPE_DESCR
VARCHAR2
400
D2_QUALITY_CNT_MV
MEASR_COMP_ID
CHAR
48
D2_QUALITY_CNT_MV
MEASR_COMP_TYPE_CD
VARCHAR2
120
D2_QUALITY_CNT_MV
MKT_CD
VARCHAR2
200
D2_QUALITY_CNT_MV
MKT_DESCR
VARCHAR2
400
D2_QUALITY_CNT_MV
MKT_REL_TYPE_DESCR
VARCHAR2
240
D2_QUALITY_CNT_MV
MKT_REL_TYPE_FLG
VARCHAR2
200
D2_QUALITY_CNT_MV
MODEL_DESCR
VARCHAR2
400
D2_QUALITY_CNT_MV
POSTAL
VARCHAR2
200
D2_QUALITY_CNT_MV
SPR_DESCR
VARCHAR2
400
D2_QUALITY_CNT_MV
SVC_TYPE_DESCR
VARCHAR2
400
D2_QUALITY_CNT_MV
USG_CALC_GRP_CD
VARCHAR2
200
D2_QUALITY_CNT_MV
USG_CALC_GRP_DESCR
VARCHAR2
400
CITY
VARCHAR2
200
D1_MODEL_CD
VARCHAR2
200
D1_SPR_CD
VARCHAR2
200
D1_SVC_TPE_CD
VARCHAR2
200
DEVICE_TYPE_CD
VARCHAR2
200
DEVICE_TYPE_DESCR
VARCHAR2
400
GEO_CODE
VARCHAR2
200
HEAD_END_SYSTEM_CD
VARCHAR2
200
VARCHAR2
400
MANUFACTURER_CD
VARCHAR2
200
MANUFACTURER_DESCR
VARCHAR2
400
MC_TYPE_DESCR
VARCHAR2
400
MEASR_COMP_ID
CHAR
48
MEASR_COMP_TYPE_CD
VARCHAR2
120
MKT_CD
VARCHAR2
200
MKT_DESCR
VARCHAR2
400
MKT_REL_TYPE_DESCR
VARCHAR2
240
MKT_REL_TYPE_FLG
VARCHAR2
200
MODEL_DESCR
VARCHAR2
400
POSTAL
VARCHAR2
200
SPR_DESCR
VARCHAR2
400
SVC_TYPE_DESCR
VARCHAR2
400
USG_CALC_GRP_CD
VARCHAR2
200
USG_CALC_GRP_DESCR
VARCHAR2
400
CITY
VARCHAR2
200
D1_MODEL_CD
VARCHAR2
200
D1_SPR_CD
VARCHAR2
200
D1_SVC_TPE_CD
VARCHAR2
200
DEVICE_TYPE_CD
VARCHAR2
200
DEVICE_TYPE_DESCR
VARCHAR2
400
GEO_CODE
VARCHAR2
200
HEAD_END_SYSTEM_CD
VARCHAR2
200
VARCHAR2
400
MANUFACTURER_CD
VARCHAR2
200
MANUFACTURER_DESCR
VARCHAR2
400
MC_TYPE_DESCR
VARCHAR2
400
MEASR_COMP_ID
CHAR
48
MEASR_COMP_TYPE_CD
VARCHAR2
120
MKT_CD
VARCHAR2
200
MKT_DESCR
VARCHAR2
400
MKT_REL_TYPE_DESCR
VARCHAR2
240
MKT_REL_TYPE_FLG
VARCHAR2
200
MODEL_DESCR
VARCHAR2
400
POSTAL
VARCHAR2
200
SPR_DESCR
VARCHAR2
400
SVC_TYPE_DESCR
VARCHAR2
400
USG_CALC_GRP_CD
VARCHAR2
200
USG_CALC_GRP_DESCR
VARCHAR2
400
LOCAL_DT
DATE
7
MEASR_COMP_ID
CHAR
48
MSRMT_DT
DATE
7
MSRMT_DTTM
DATE
7
MSRMT_LOCAL_DTTM
DATE
7
MSRMT_VAL
NUMBER
22
MSRMT_VAL1
NUMBER
22
MSRMT_VAL10
NUMBER
22
MSRMT_VAL2
NUMBER
22
MSRMT_VAL3
NUMBER
22
MSRMT_VAL4
NUMBER
22
MSRMT_VAL5
NUMBER
22
MSRMT_VAL6
NUMBER
22
MSRMT_VAL7
NUMBER
22
MSRMT_VAL8
NUMBER
22
MSRMT_VAL9
NUMBER
22
LOCAL_DT
DATE
7
MEASR_COMP_ID
CHAR
48
MSRMT_DT
DATE
7
MSRMT_DTTM
DATE
7
MSRMT_LOCAL_DTTM
DATE
7
MSRMT_VAL
NUMBER
22
MSRMT_VAL1
NUMBER
22
MSRMT_VAL10
NUMBER
22
MSRMT_VAL2
NUMBER
22
MSRMT_VAL3
NUMBER
22
MSRMT_VAL4
NUMBER
22
MSRMT_VAL5
NUMBER
22
MSRMT_VAL6
NUMBER
22
MSRMT_VAL7
NUMBER
22
MSRMT_VAL8
NUMBER
22
MSRMT_VAL9
NUMBER
22
F1_ACTION_METHOD
ACTION_METHOD_CD
VARCHAR2
120
F1_ACTION_METHOD
ACTION_METHOD_ROLE_XFLG
VARCHAR2
120
F1_ACTION_METHOD
BO_XML_DATA_AREA
XMLTYPE
2000
F1_ACTION_METHOD
BUS_OBJ_CD
CHAR
120
F1_ACTION_METHOD
VERSION
NUMBER
22
F1_ACTION_METHOD_CHAR
ACTION_METHOD_CD
VARCHAR2
120
ADHOC_CHAR_VAL
VARCHAR2
1016
CHAR_TYPE_CD
CHAR
32
CHAR_VAL
CHAR
64
CHAR_VAL_FK1
VARCHAR2
200
CHAR_VAL_FK2
VARCHAR2
200
CHAR_VAL_FK3
VARCHAR2
200
CHAR_VAL_FK4
VARCHAR2
200
CHAR_VAL_FK5
VARCHAR2
200
SEQ_NUM
NUMBER
22
SRCH_CHAR_VAL
VARCHAR2
200
VERSION
NUMBER
22
F1_ACTION_METHOD_L
ACTION_METHOD_CD
VARCHAR2
120
F1_ACTION_METHOD_L
DESCR100
VARCHAR2
400
F1_ACTION_METHOD_L
DESCRLONG
VARCHAR2
16000
F1_ACTION_METHOD_L
LANGUAGE_CD
CHAR
12
F1_ACTION_METHOD_L
VERSION
NUMBER
22
F1_ARC_TBL_PARTITION_HIST
ACTUAL_DROP_DTTM
DATE
7
APPROVAL_DROP_DTTM
DATE
7
APPROVAL_USER_ID
CHAR
32
ARCHIVE_DTTM
DATE
7
ARCHIVE_FILE_NAME
VARCHAR2
512
ARCHIVE_METHOD_FLG
CHAR
16
CRE_DTTM
DATE
7
DROP_APPROVAL_FLG
CHAR
16
DROP_PART_STAT_FLG
CHAR
16
ESTIMATED_SIZE_GB
NUMBER
22
PARTITION_MON
VARCHAR2
12
PARTITION_YEAR
NUMBER
22
PART_OR_SUBPART_NAME
VARCHAR2
512
REPEAT_DTTM
DATE
7
REPEAT_FLG
CHAR
16
REPEAT_USER_ID
CHAR
32
RETENTION_OR_SUBRET_DAYS
NUMBER
22
SCHED_DROP_DTTM
DATE
7
TBL_NAME
CHAR
120
TBL_OWNER
VARCHAR2
512
F1_ATTACHMENT
ATTCH_CONT_LOC_FLG
CHAR
16
F1_ATTACHMENT
ATTCH_FILE_REF
VARCHAR2
8000
F1_ATTACHMENT_DATA
ATTACHMENT_ID
CHAR
56
F1_ATTACHMENT_DATA
ATTCH_DATA_USAGE_FLG
CHAR
16
F1_ATTACHMENT_DATA
ATTCH_FILE_DETAILS
CLOB
4000
F1_ATTACHMENT_DATA
SEQNO
NUMBER
22
F1_BATCH_CONF_VW
AVG_ELAPSED
NUMBER
22
F1_BATCH_CONF_VW
BATCH_CD
CHAR
32
F1_BATCH_CONF_VW
BATCH_PERF_COUNT
NUMBER
22
F1_BATCH_CONF_VW
BEST_ELAPSED
NUMBER
22
F1_BATCH_CONF_VW
CONFIDENCE
NUMBER
22
F1_BATCH_CONF_VW
MED_ELAPSED
NUMBER
22
F1_BATCH_CONF_VW
SAMPLE_SIZE
NUMBER
22
F1_BATCH_CONF_VW
STD_DEVIATION
NUMBER
22
F1_BATCH_CONF_VW
WORST_ELAPSED
NUMBER
22
F1_BATCH_RUN_ANALYTICS_SNAP
BATCH_BUS_DT
DATE
7
BATCH_CD
CHAR
32
BATCH_JOB_ID
CHAR
56
BATCH_JOB_STAT_FLG
CHAR
8
BATCH_NBR
NUMBER
22
BATCH_RERUN_NBR
NUMBER
22
CRE_DTTM
DATE
7
DO_NOT_RESTART_SW
CHAR
4
ELAPSED_SECS
NUMBER
22
END_DTTM
DATE
7
PROCESS_DT
DATE
7
REC_ERR_CNT
NUMBER
22
REC_PROC_CNT
NUMBER
22
RUN_STATUS
CHAR
8
START_DTTM
DATE
7
SUBMIT_METH_FLG
CHAR
16
SUBMIT_USER_ID
CHAR
32
THREADPOOL
VARCHAR2
1016
USER_ID
CHAR
32
VERSION
NUMBER
22
F1_BATCH_RUN_HIST_VW
BATCH_BUS_DT
DATE
7
BATCH_CD
CHAR
32
BATCH_JOB_ID
CHAR
56
BATCH_NBR
NUMBER
22
BATCH_RERUN_NBR
NUMBER
22
BATCH_RUN_COUNT
NUMBER
22
DO_NOT_RESTART_SW
CHAR
4
ELAPSED_TIME
NUMBER
22
END_DTTM
DATE
7
PROCESS_DT
DATE
7
RUN_STATUS
CHAR
8
START_DTTM
DATE
7
SUBMIT_METH_FLG
CHAR
16
SUBMIT_USER_ID
CHAR
32
THREADPOOL
VARCHAR2
1016
TOTAL_ERROR
NUMBER
22
TOTAL_PROCESSED
NUMBER
22
USER_ID
CHAR
32
F1_BATCH_THD_ANALYTICS_SNAP
BATCH_BUS_DT
DATE
7
BATCH_CD
CHAR
32
BATCH_JOB_ID
CHAR
56
BATCH_NBR
NUMBER
22
BATCH_RERUN_NBR
NUMBER
22
BATCH_THREAD_NBR
NUMBER
22
CRE_DTTM
DATE
7
END_DT
DATE
7
END_DTTM
DATE
7
REC_ERR_CNT
NUMBER
22
REC_PROC_CNT
NUMBER
22
RUN_STATUS
CHAR
8
SCHEDULER_ID
NUMBER
22
START_DT
DATE
7
START_DTTM
DATE
7
SUBMIT_METH_FLG
CHAR
16
SUBMIT_USER_ID
CHAR
32
THD_RETRY_CNT
NUMBER
22
THREADPOOL
VARCHAR2
1016
THREAD_STATUS
CHAR
8
VERSION
NUMBER
22
F1_BATCH_THD_CAP_VW
BATCH_BUS_DT
DATE
7
F1_BATCH_THD_CAP_VW
BATCH_CD
CHAR
32
F1_BATCH_THD_CAP_VW
BATCH_JOB_ID
CHAR
56
F1_BATCH_THD_CAP_VW
BATCH_NBR
NUMBER
22
F1_BATCH_THD_CAP_VW
BATCH_RERUN_NBR
NUMBER
22
F1_BATCH_THD_CAP_VW
BATCH_THREAD_CAP_COUNT
NUMBER
22
F1_BATCH_THD_CAP_VW
BATCH_THREAD_NBR
NUMBER
22
F1_BATCH_THD_CAP_VW
END_DT
DATE
7
F1_BATCH_THD_CAP_VW
F1_MINUTE_IN_DAY
NUMBER
22
F1_BATCH_THD_CAP_VW
F1_TIME_KEY
CHAR
16
F1_BATCH_THD_CAP_VW
JOB_END_MINS
NUMBER
22
F1_BATCH_THD_CAP_VW
JOB_START_MINS
NUMBER
22
F1_BATCH_THD_CAP_VW
RUN_PROCESSING_DT
DATE
7
F1_BATCH_THD_CAP_VW
START_DT
DATE
7
F1_BATCH_THD_CAP_VW
SUBMIT_METH_FLG
CHAR
16
F1_BATCH_THD_CAP_VW
SUBMIT_USER_ID
CHAR
32
F1_BATCH_THD_CAP_VW
THREADPOOL
VARCHAR2
1016
F1_BATCH_THD_CAP_VW
THREAD_END_DTTM
DATE
7
F1_BATCH_THD_CAP_VW
THREAD_START_DTTM
DATE
7
F1_BATCH_THD_HIST_VW
BATCH_BUS_DT
DATE
7
BATCH_CD
CHAR
32
BATCH_JOB_ID
CHAR
56
BATCH_NBR
NUMBER
22
BATCH_RERUN_NBR
NUMBER
22
BATCH_RUN_THD_COUNT
NUMBER
22
BATCH_THREAD_NBR
NUMBER
22
ELAPSED_TIME
NUMBER
22
PROCESS_DT
DATE
7
RECS_PER_MINUTE
NUMBER
22
RETRY_COUNT
NUMBER
22
RUN_STATUS
CHAR
8
THREADPOOL
VARCHAR2
1016
THREAD_END_DTTM
DATE
7
THREAD_START_DTTM
DATE
7
THREAD_STATUS
CHAR
8
TOTAL_ERROR
NUMBER
22
TOTAL_PROCESSED
NUMBER
22
F1_BATCH_VOL_VW
BATCH_CD
CHAR
32
F1_BATCH_VOL_VW
BATCH_NBR
NUMBER
22
F1_BATCH_VOL_VW
BATCH_RERUN_NBR
NUMBER
22
F1_BATCH_VOL_VW
BATCH_THD_VOL_COUNT
NUMBER
22
F1_BATCH_VOL_VW
MAX_PROCESSED
NUMBER
22
F1_BATCH_VOL_VW
RECS_PER_MINUTE
NUMBER
22
F1_BATCH_VOL_VW
TOTAL_PROCESSED
NUMBER
22
F1_BUS_OBJ_STATUS_L
DESCR_OVRD
VARCHAR2
240
F1_BUS_OBJ_STATUS_RSN_L
DESCR_OVRD
VARCHAR2
240
F1_BUS_OBJ_STATUS_RSN_VW
BO_STATUS_REASON_CD
VARCHAR2
120
DESCR
VARCHAR2
240
DESCRLONG
VARCHAR2
16000
LANGUAGE_CD
CHAR
12
OWNER_FLG
CHAR
16
VERSION
NUMBER
22
F1_BUS_OBJ_STATUS_VW
BO_STATUS_CD
CHAR
48
BUS_OBJ_CD
CHAR
120
DESCR
VARCHAR2
240
DESCRLONG
VARCHAR2
16000
LANGUAGE_CD
CHAR
12
OWNER_FLG
CHAR
16
VERSION
NUMBER
22
F1_BUS_OBJ_TR_RULE_L
BO_NEXT_STATUS_OVRD_LBL
VARCHAR2
240
F1_CAL_FISC_PERIOD_D
F1_FISC_PERIOD_END_DT
DATE
7
F1_FISC_PERIOD_FLG
CHAR
16
F1_FISC_PERIOD_IN_QUARTER
NUMBER
22
F1_FISC_PERIOD_IN_YEAR
NUMBER
22
F1_FISC_PERIOD_KEY
NUMBER
22
F1_FISC_PERIOD_START_DT
DATE
7
F1_FISC_QUARTER_END_DT
DATE
7
F1_FISC_QUARTER_FLG
CHAR
16
F1_FISC_QUARTER_IN_YEAR
NUMBER
22
F1_FISC_QUARTER_KEY
NUMBER
22
F1_FISC_QUARTER_START_DT
DATE
7
F1_FISC_YEAR
NUMBER
22
F1_FISC_YEAR_END_DT
DATE
7
F1_FISC_YEAR_START_DT
DATE
7
F1_CAL_FISC_QUARTER_D
DATE
7
F1_FISC_QUARTER_FLG
CHAR
16
NUMBER
22
F1_FISC_QUARTER_KEY
NUMBER
22
DATE
7
F1_FISC_YEAR
NUMBER
22
F1_FISC_YEAR_END_DT
DATE
7
DATE
7
F1_CAL_FISC_YEAR_D
F1_FISC_YEAR
NUMBER
22
F1_CAL_FISC_YEAR_D
F1_FISC_YEAR_END_DT
DATE
7
F1_CAL_FISC_YEAR_D
DATE
7
F1_CAL_MONTH_D
F1MONTH_ABBR
CHAR
16
F1_CAL_MONTH_D
F1_CAL_QUARTER_END_DT
DATE
7
F1_CAL_MONTH_D
F1_CAL_QUARTER_FLG
CHAR
16
F1_CAL_MONTH_D
F1_CAL_QUARTER_IN_YEAR
NUMBER
22
F1_CAL_MONTH_D
F1_CAL_QUARTER_KEY
NUMBER
22
F1_CAL_MONTH_D
F1_CAL_QUARTER_START_DT
DATE
7
F1_CAL_MONTH_D
F1_CAL_YEAR
NUMBER
22
F1_CAL_MONTH_D
F1_CAL_YEAR_END_DT
DATE
7
F1_CAL_MONTH_D
F1_CAL_YEAR_NAME
CHAR
16
F1_CAL_MONTH_D
F1_CAL_YEAR_START_DT
DATE
7
F1_CAL_MONTH_D
F1_MONTH_END_DT
DATE
7
F1_CAL_MONTH_D
F1_MONTH_IN_QUARTER
NUMBER
22
F1_CAL_MONTH_D
F1_MONTH_IN_YEAR
NUMBER
22
F1_CAL_MONTH_D
F1_MONTH_KEY
NUMBER
22
F1_CAL_MONTH_D
F1_MONTH_START_DT
DATE
7
F1_CAL_QUARTER_D
DATE
7
F1_CAL_QUARTER_D
F1_CAL_QUARTER_FLG
CHAR
16
F1_CAL_QUARTER_D
NUMBER
22
F1_CAL_QUARTER_D
F1_CAL_QUARTER_KEY
NUMBER
22
F1_CAL_QUARTER_D
DATE
7
F1_CAL_QUARTER_D
F1_CAL_YEAR
NUMBER
22
F1_CAL_QUARTER_D
F1_CAL_YEAR_END_DT
DATE
7
F1_CAL_QUARTER_D
F1_CAL_YEAR_NAME
CHAR
16
F1_CAL_QUARTER_D
DATE
7
F1_CAL_WEEK_D
F1_WEEK_END_DT
DATE
7
F1_CAL_WEEK_D
F1_WEEK_IN_YEAR
NUMBER
22
F1_CAL_WEEK_D
F1_WEEK_KEY
NUMBER
22
F1_CAL_WEEK_D
F1_WEEK_NAME
CHAR
28
F1_CAL_WEEK_D
F1_WEEK_START_DT
DATE
7
F1_CAL_YEAR_D
F1_CAL_YEAR
NUMBER
22
F1_CAL_YEAR_D
F1_CAL_YEAR_END_DT
DATE
7
F1_CAL_YEAR_D
F1_CAL_YEAR_NAME
CHAR
16
F1_CAL_YEAR_D
DATE
7
F1_COLOR_OPT
BACKGROUND_COLOR_XFLG
VARCHAR2
120
F1_COLOR_OPT
BO_XML_DATA_AREA
XMLTYPE
2000
F1_COLOR_OPT
BUS_OBJ_CD
CHAR
120
F1_COLOR_OPT
COLOR_OPT_CD
VARCHAR2
120
F1_COLOR_OPT
COLOR_OPT_CLASS_FLG
CHAR
16
F1_COLOR_OPT
FOREGROUND_COLOR_XFLG
VARCHAR2
120
F1_COLOR_OPT
OWNER_FLG
CHAR
16
F1_COLOR_OPT
VERSION
NUMBER
22
F1_COLOR_OPT_ITEM
COLOR_OPT_CD
VARCHAR2
120
F1_COLOR_OPT_ITEM
ITEM_BACKGROUND_COLOR_XFLG
VARCHAR2
120
F1_COLOR_OPT_ITEM
ITEM_FOREGROUND_COLOR_XFLG
VARCHAR2
120
F1_COLOR_OPT_ITEM
OWNER_FLG
CHAR
16
F1_COLOR_OPT_ITEM
SEQNO
NUMBER
22
F1_COLOR_OPT_ITEM
VERSION
NUMBER
22
F1_COLOR_OPT_L
COLOR_OPT_CD
VARCHAR2
120
F1_COLOR_OPT_L
DESCR100
VARCHAR2
400
F1_COLOR_OPT_L
LANGUAGE_CD
CHAR
12
F1_COLOR_OPT_L
OWNER_FLG
CHAR
16
F1_COLOR_OPT_L
VERSION
NUMBER
22
F1_CRYPTO_KEY
PUBLIC_KEY
VARCHAR2
32767
F1_CRYPTO_KEY_RING
KEY_RING_CAT_FLG
CHAR
16
F1_CRYPTO_KEY_RING
OWNER_FLG
CHAR
16
F1_CRYPTO_KEY_RING_L
OWNER_FLG
CHAR
16
F1_DATA_EXPORT_CTRL
BUS_OBJ_CD
CHAR
120
F1_DATA_EXPORT_CTRL
CRE_DTTM
DATE
7
F1_DATA_EXPORT_CTRL
F1_DATA_EXPORT_CD
VARCHAR2
120
F1_DATA_EXPORT_CTRL
F1_DATA_EXPORT_CLS_FLG
CHAR
16
F1_DATA_EXPORT_CTRL
F1_EXPORT_THRU_DTTM
DATE
7
F1_DATA_EXPORT_CTRL
F1_INIT_EXPORT_FLG
CHAR
16
F1_DATA_EXPORT_CTRL
F1_ONGEXP_STATUS_FLG
CHAR
16
F1_DATA_EXPORT_CTRL
MAINT_OBJ_CD
CHAR
48
F1_DATA_EXPORT_CTRL
VERSION
NUMBER
22
F1_DATA_EXPORT_CTRL_LOG
ADHOC_CHAR_VAL
VARCHAR2
1016
CHAR_TYPE_CD
CHAR
32
CHAR_VAL
CHAR
64
CHAR_VAL_FK1
VARCHAR2
200
CHAR_VAL_FK2
VARCHAR2
200
CHAR_VAL_FK3
VARCHAR2
200
CHAR_VAL_FK4
VARCHAR2
200
CHAR_VAL_FK5
VARCHAR2
200
DESCRLONG
VARCHAR2
16000
F1_DATA_EXPORT_CD
VARCHAR2
120
LOG_DTTM
DATE
7
LOG_ENTRY_TYPE_FLG
CHAR
16
MESSAGE_CAT_NBR
NUMBER
22
MESSAGE_NBR
NUMBER
22
SEQNO
NUMBER
22
USER_ID
CHAR
32
VERSION
NUMBER
22
F1_DATA_EXPORT_CTRL_LOG_PARM
F1_DATA_EXPORT_CD
VARCHAR2
120
MSG_PARM_TYP_FLG
CHAR
16
MSG_PARM_VAL
VARCHAR2
8000
PARM_SEQ
NUMBER
22
SEQNO
NUMBER
22
VERSION
NUMBER
22
F1_ETL_MP_CTRL
F1_BI_TYPE_FLD
CHAR
120
F1_ETL_MP_CTRL
F1_BI_TYPE_VALUE
CHAR
16
F1_EXTSYS_OUTMSG_PROF
OWNER_FLG
CHAR
16
F1_FILE_INT_REC
BO_XML_DATA_AREA
XMLTYPE
2000
F1_FILE_INT_REC
BUS_OBJ_CD
CHAR
120
F1_FILE_INT_REC
DATA_AREA_CD
CHAR
120
F1_FILE_INT_REC
FILE_INT_REC_CD
VARCHAR2
120
F1_FILE_INT_REC
FILE_INT_REC_STATUS_FLG
CHAR
16
F1_FILE_INT_REC
FILE_INT_TYPE_CD
VARCHAR2
120
F1_FILE_INT_REC
OWNER_FLG
CHAR
16
F1_FILE_INT_REC
PRNT_SEQ
NUMBER
22
F1_FILE_INT_REC
ROOT_ELEM
VARCHAR2
400
F1_FILE_INT_REC
SEQNO
NUMBER
22
F1_FILE_INT_REC
VERSION
NUMBER
22
F1_FILE_INT_REC_ALG
ALG_CD
CHAR
48
F1_FILE_INT_REC_ALG
FILE_INT_REC_CD
VARCHAR2
120
F1_FILE_INT_REC_ALG
FILE_INT_REC_SEVT_FLG
CHAR
16
F1_FILE_INT_REC_ALG
FILE_INT_TYPE_CD
VARCHAR2
120
F1_FILE_INT_REC_ALG
OWNER_FLG
CHAR
16
F1_FILE_INT_REC_ALG
SEQ_NUM
NUMBER
22
F1_FILE_INT_REC_ALG
VERSION
NUMBER
22
F1_FILE_INT_REC_L
DESCR100
VARCHAR2
400
F1_FILE_INT_REC_L
DESCR4000
VARCHAR2
16000
F1_FILE_INT_REC_L
FILE_INT_REC_CD
VARCHAR2
120
F1_FILE_INT_REC_L
FILE_INT_TYPE_CD
VARCHAR2
120
F1_FILE_INT_REC_L
LANGUAGE_CD
CHAR
12
F1_FILE_INT_REC_L
OWNER_FLG
CHAR
16
F1_FILE_INT_REC_L
VERSION
NUMBER
22
F1_FILE_INT_TYPE
BO_XML_DATA_AREA
XMLTYPE
2000
F1_FILE_INT_TYPE
BUS_OBJ_CD
CHAR
120
F1_FILE_INT_TYPE
FILE_INT_CLASS_FLG
CHAR
16
F1_FILE_INT_TYPE
FILE_INT_OBJ_FLG
CHAR
16
F1_FILE_INT_TYPE
FILE_INT_STATUS_FLG
CHAR
16
F1_FILE_INT_TYPE
FILE_INT_TYPE_CD
VARCHAR2
120
F1_FILE_INT_TYPE
OWNER_FLG
CHAR
16
F1_FILE_INT_TYPE
VERSION
NUMBER
22
F1_FILE_INT_TYPE_L
DESCR100
VARCHAR2
400
F1_FILE_INT_TYPE_L
DESCR4000
VARCHAR2
16000
F1_FILE_INT_TYPE_L
FILE_INT_TYPE_CD
VARCHAR2
120
F1_FILE_INT_TYPE_L
LANGUAGE_CD
CHAR
12
F1_FILE_INT_TYPE_L
OWNER_FLG
CHAR
16
F1_FILE_INT_TYPE_L
VERSION
NUMBER
22
F1_INSIGHT_GRP
BO_XML_DATA_AREA
XMLTYPE
2000
F1_INSIGHT_GRP
BUS_OBJ_CD
CHAR
120
F1_INSIGHT_GRP
INSIGHT_CLASS_FLG
CHAR
16
F1_INSIGHT_GRP
INSIGHT_GRP_CD
VARCHAR2
120
F1_INSIGHT_GRP
VERSION
NUMBER
22
F1_INSIGHT_GRP_CHAR
ADHOC_CHAR_VAL
VARCHAR2
1016
F1_INSIGHT_GRP_CHAR
CHAR_TYPE_CD
CHAR
32
F1_INSIGHT_GRP_CHAR
CHAR_VAL
CHAR
64
F1_INSIGHT_GRP_CHAR
CHAR_VAL_FK1
VARCHAR2
200
F1_INSIGHT_GRP_CHAR
CHAR_VAL_FK2
VARCHAR2
200
F1_INSIGHT_GRP_CHAR
CHAR_VAL_FK3
VARCHAR2
200
F1_INSIGHT_GRP_CHAR
CHAR_VAL_FK4
VARCHAR2
200
F1_INSIGHT_GRP_CHAR
CHAR_VAL_FK5
VARCHAR2
200
F1_INSIGHT_GRP_CHAR
INSIGHT_GRP_CD
VARCHAR2
120
F1_INSIGHT_GRP_CHAR
SEQ_NUM
NUMBER
22
F1_INSIGHT_GRP_CHAR
SRCH_CHAR_VAL
VARCHAR2
200
F1_INSIGHT_GRP_CHAR
VERSION
NUMBER
22
F1_INSIGHT_GRP_L
DESCR100
VARCHAR2
400
F1_INSIGHT_GRP_L
DESCRLONG
VARCHAR2
16000
F1_INSIGHT_GRP_L
INSIGHT_GRP_CD
VARCHAR2
120
F1_INSIGHT_GRP_L
LANGUAGE_CD
CHAR
12
F1_INSIGHT_GRP_L
VERSION
NUMBER
22
F1_INSIGHT_GRP_TYPE
INSIGHT_GRP_CD
VARCHAR2
120
F1_INSIGHT_GRP_TYPE
INSIGHT_TYPE_CD
VARCHAR2
120
F1_INSIGHT_GRP_TYPE
SEQ_NUM
NUMBER
22
F1_INSIGHT_GRP_TYPE
VERSION
NUMBER
22
F1_INSIGHT_GRP_VISUAL_STR
INSIGHT_GRP_CD
VARCHAR2
120
VERSION
NUMBER
22
VISUAL_STRUCTURE_FLG
CHAR
16
F1_INSIGHT_TYPE
BO_XML_DATA_AREA
XMLTYPE
2000
F1_INSIGHT_TYPE
BUS_OBJ_CD
CHAR
120
F1_INSIGHT_TYPE
INSIGHT_ACT_TRACK_FLG
CHAR
16
F1_INSIGHT_TYPE
INSIGHT_TYPE_CD
VARCHAR2
120
F1_INSIGHT_TYPE
OWNER_FLG
CHAR
16
F1_INSIGHT_TYPE
VERSION
NUMBER
22
F1_INSIGHT_TYPE
CHAR
16
F1_INSIGHT_TYPE_ALG
ALG_CD
CHAR
48
F1_INSIGHT_TYPE_ALG
INSIGHT_SEVT_FLG
CHAR
16
F1_INSIGHT_TYPE_ALG
INSIGHT_TYPE_CD
VARCHAR2
120
F1_INSIGHT_TYPE_ALG
OWNER_FLG
CHAR
16
F1_INSIGHT_TYPE_ALG
SEQ_NUM
NUMBER
22
F1_INSIGHT_TYPE_ALG
VERSION
NUMBER
22
F1_INSIGHT_TYPE_CHAR
ADHOC_CHAR_VAL
VARCHAR2
1016
CHAR_TYPE_CD
CHAR
32
CHAR_VAL
CHAR
64
CHAR_VAL_FK1
VARCHAR2
200
CHAR_VAL_FK2
VARCHAR2
200
CHAR_VAL_FK3
VARCHAR2
200
CHAR_VAL_FK4
VARCHAR2
200
CHAR_VAL_FK5
VARCHAR2
200
INSIGHT_TYPE_CD
VARCHAR2
120
OWNER_FLG
CHAR
16
SEQ_NUM
NUMBER
22
SRCH_CHAR_VAL
VARCHAR2
200
VERSION
NUMBER
22
F1_INSIGHT_TYPE_L
DESCR100
VARCHAR2
400
F1_INSIGHT_TYPE_L
DESCRLONG
VARCHAR2
16000
F1_INSIGHT_TYPE_L
INSIGHT_TYPE_CD
VARCHAR2
120
F1_INSIGHT_TYPE_L
LANGUAGE_CD
CHAR
12
F1_INSIGHT_TYPE_L
OWNER_FLG
CHAR
16
F1_INSIGHT_TYPE_L
VERSION
NUMBER
22
F1_INSIGHT_TYPE_USER_ACT
INSIGHT_ACT_CD
VARCHAR2
120
INSIGHT_ACT_CLASS_FLG
CHAR
16
INSIGHT_ACT_DISP_TYPE
CHAR
16
INSIGHT_ACT_FLD_FLG
CHAR
16
INSIGHT_TYPE_CD
VARCHAR2
120
OWNER_FLG
CHAR
16
SCR_CD
CHAR
48
VERSION
NUMBER
22
F1_INSIGHT_TYPE_USER_ACT_ALG
ALG_CD
CHAR
48
INSIGHT_ACT_CD
VARCHAR2
120
INSIGHT_ACT_SEVT_FLG
CHAR
16
INSIGHT_TYPE_CD
VARCHAR2
120
OWNER_FLG
CHAR
16
SEQ_NUM
NUMBER
22
VERSION
NUMBER
22
F1_INSIGHT_TYPE_VISUAL_SETTING
DISP_ICON_CD
CHAR
48
HEADER_CAT_FLG
CHAR
16
HEADER_COLOR_OPT_CD
VARCHAR2
120
ICON_COLOR_OPT_CD
VARCHAR2
120
INSIGHT_COLOR_OPT_CD
VARCHAR2
120
INSIGHT_TYPE_CD
VARCHAR2
120
OWNER_FLG
CHAR
16
SEQ_NUM
NUMBER
22
SEVERITY_VAL
NUMBER
22
VERSION
NUMBER
22
VISUAL_SETTING_TYPE_FLG
CHAR
16
F1_IWS_SVC
IWS_REST_VER_FLG
CHAR
16
F1_IWS_SVC
PUBLISH_FLG
CHAR
16
F1_IWS_SVC_FLDTEXT
EXAMPLE_TEXT
VARCHAR2
16000
F1_IWS_SVC_FLDTEXT
FLD_NAME
CHAR
120
F1_IWS_SVC_FLDTEXT
IN_SVC_NAME
VARCHAR2
1016
F1_IWS_SVC_FLDTEXT
IWS_HELP_TEXT
VARCHAR2
16000
F1_IWS_SVC_FLDTEXT
OWNER_FLG
CHAR
16
F1_IWS_SVC_FLDTEXT
TEXT_NAME
CHAR
120
F1_IWS_SVC_FLDTEXT
VERSION
NUMBER
22
F1_IWS_SVC_OPER
MAINT_OBJ_CD
CHAR
48
F1_IWS_SVC_OPER
SEQ_NUM
NUMBER
22
F1_IWS_SVC_OPER_L
DESCR
VARCHAR2
240
F1_IWS_SVC_OPER_L
DESCRLONG
VARCHAR2
16000
F1_IWS_SVC_OPER_L
IN_SVC_NAME
VARCHAR2
1016
F1_IWS_SVC_OPER_L
LANGUAGE_CD
CHAR
12
F1_IWS_SVC_OPER_L
OPERATION_NAME
VARCHAR2
1016
F1_IWS_SVC_OPER_L
OWNER_FLG
CHAR
16
F1_IWS_SVC_OPER_L
VERSION
NUMBER
22
F1_IWS_SVC_OPER_OPT
IN_SVC_NAME
VARCHAR2
1016
F1_IWS_SVC_OPER_OPT
IWS_OPR_OPT_FLG
CHAR
16
F1_IWS_SVC_OPER_OPT
IWS_OPR_OPT_VAL
VARCHAR2
32767
F1_IWS_SVC_OPER_OPT
OPERATION_NAME
VARCHAR2
1016
F1_IWS_SVC_OPER_OPT
OWNER_FLG
CHAR
16
F1_IWS_SVC_OPER_OPT
SEQ_NUM
NUMBER
22
F1_IWS_SVC_OPER_OPT
VERSION
NUMBER
22
F1_IWS_SVC_SCHEMA
IN_SVC_NAME
VARCHAR2
1016
F1_IWS_SVC_SCHEMA
IWS_SCHEMA_DEFN
CLOB
4000
F1_IWS_SVC_SCHEMA
IWS_SCHEMA_NAME
VARCHAR2
1016
F1_IWS_SVC_SCHEMA
IWS_SCHEMA_TYPE_FLG
CHAR
16
F1_IWS_SVC_SCHEMA
OWNER_FLG
CHAR
16
F1_IWS_SVC_SCHEMA
VERSION
NUMBER
22
F1_LGCY_OBJ
CHANGE_REF_NAME
VARCHAR2
120
F1_LGCY_OBJ
LGCY_CAT_FLG
CHAR
16
F1_MD_BI_TBL
BUS_OBJ_CD
CHAR
120
F1_MD_BI_TBL
F1_BI_HIER_DEFN
VARCHAR2
32767
F1_MD_BI_TBL
F1_BI_NAME
VARCHAR2
400
F1_MD_BI_TBL
F1_BI_TABLE_TYPE_FLG
CHAR
16
F1_MD_BI_TBL
F1_BI_TBL_NAME
CHAR
120
F1_MD_BI_TBL
OWNER_FLG
CHAR
16
F1_MD_BI_TBL
TBL_NAME
CHAR
120
F1_MD_BI_TBL
VERSION
NUMBER
22
F1_MD_BI_TBL_FLD
BI_ELEM_NAME
VARCHAR2
240
F1_MD_BI_TBL_FLD
F1_AGG_RULE_FLG
CHAR
16
F1_MD_BI_TBL_FLD
F1_BI_FLD_TYPE_FLG
CHAR
16
F1_MD_BI_TBL_FLD
F1_BI_TBL_NAME
CHAR
120
F1_MD_BI_TBL_FLD
F1_BUCKET_BO
VARCHAR2
120
F1_MD_BI_TBL_FLD
F1_CALC_EXP
VARCHAR2
16000
F1_MD_BI_TBL_FLD
F1_DEGENERATE_SW
CHAR
4
F1_MD_BI_TBL_FLD
F1_DISP_SEQ_NUM
NUMBER
22
F1_MD_BI_TBL_FLD
F1_HIDE_TIME_SW
CHAR
4
F1_MD_BI_TBL_FLD
F1_INTERNAL_SW
CHAR
4
F1_MD_BI_TBL_FLD
F1_PROC_OPT_FLG
CHAR
16
F1_MD_BI_TBL_FLD
FLD_NAME
CHAR
120
F1_MD_BI_TBL_FLD
LOGICAL_DM_NAME
VARCHAR2
240
F1_MD_BI_TBL_FLD
OVRD_FLD_NAME
CHAR
120
F1_MD_BI_TBL_FLD
OWNER_FLG
CHAR
16
F1_MD_BI_TBL_FLD
SEQ_NUM
NUMBER
22
F1_MD_BI_TBL_FLD
VERSION
NUMBER
22
F1_MD_BI_TBL_L
DESCR100
VARCHAR2
400
F1_MD_BI_TBL_L
DESCRLONG
VARCHAR2
16000
F1_MD_BI_TBL_L
F1_BI_TBL_NAME
CHAR
120
F1_MD_BI_TBL_L
LANGUAGE_CD
CHAR
12
F1_MD_BI_TBL_L
OWNER_FLG
CHAR
16
F1_MD_BI_TBL_L
VERSION
NUMBER
22
F1_MENU_APP_SVCS_VW
APP_SVC_ID
CHAR
80
F1_MENU_APP_SVCS_VW
LINE_VISIBILITY_SW
CHAR
4
F1_MENU_APP_SVCS_VW
MENU_LINE_ID
CHAR
40
F1_MIGR_DATA_ST
BULK_IMPORT_FLG
CHAR
16
F1_MIGR_DATA_ST
INSERT_ONLY_FLG
CHAR
16
F1_MIGR_DATA_ST
MIGR_FILEVERSION
NUMBER
22
F1_MIGR_DATA_ST
REDACT_OPT_FLG
CHAR
16
F1_MIGR_DATA_ST_TBL
RECORD_COUNT
NUMBER
22
F1_MIGR_OBJ
ENTITIES_CNT
NUMBER
22
F1_MIGR_OBJ_DATA
MIGR_OBJ_ID
CHAR
56
F1_MIGR_OBJ_DATA
SEQ_NUM
NUMBER
22
F1_MIGR_OBJ_DATA
TBL_DATA
CLOB
4000
F1_MIGR_OBJ_DATA
VERSION
NUMBER
22
F1_MIGR_OBJ_SQL
PK_VALUE1
VARCHAR2
1016
F1_MIGR_OBJ_SQL
PK_VALUE2
VARCHAR2
1016
F1_MIGR_OBJ_SQL
PK_VALUE3
VARCHAR2
1016
F1_MIGR_OBJ_SQL
PK_VALUE4
VARCHAR2
1016
F1_MIGR_OBJ_SQL
PK_VALUE5
VARCHAR2
1016
F1_MIGR_REQ_INSTR
ENTITY_TAG
VARCHAR2
120
F1_MO_UPD
ENT_KEY_HASH
NUMBER
22
F1_MO_UPD
MAINT_OBJ_CD
CHAR
48
F1_MO_UPD
PK_VALUE1
VARCHAR2
1016
F1_MO_UPD
PK_VALUE2
VARCHAR2
1016
F1_MO_UPD
PK_VALUE3
VARCHAR2
1016
F1_MO_UPD
PK_VALUE4
VARCHAR2
1016
F1_MO_UPD
PK_VALUE5
VARCHAR2
1016
F1_MO_UPD_BACKLOG
ENT_KEY_HASH
NUMBER
22
F1_MO_UPD_BACKLOG
MAINT_OBJ_CD
CHAR
48
F1_MO_UPD_BACKLOG
PK_VALUE1
VARCHAR2
1016
F1_MO_UPD_BACKLOG
PK_VALUE2
VARCHAR2
1016
F1_MO_UPD_BACKLOG
PK_VALUE3
VARCHAR2
1016
F1_MO_UPD_BACKLOG
PK_VALUE4
VARCHAR2
1016
F1_MO_UPD_BACKLOG
PK_VALUE5
VARCHAR2
1016
F1_MO_UPD_BACKLOG
REC_ROW_ID
VARCHAR2
400
F1_MO_UPD_BACKUP
BATCH_CD
CHAR
32
F1_MO_UPD_BACKUP
BATCH_NBR
NUMBER
22
F1_MO_UPD_BACKUP
BATCH_THREAD_NBR
NUMBER
22
F1_MO_UPD_BACKUP
CRE_DTTM
DATE
7
F1_MO_UPD_BACKUP
EXPORTED_KEYS
CLOB
4000
F1_MST_CONFIG
CONFIG_CLS_FLG
CHAR
16
F1_MST_CONFIG
CONFIG_PART_NAME
VARCHAR2
1016
F1_MST_CONFIG_CHAR
ADHOC_CHAR_VAL
VARCHAR2
1016
F1_MST_CONFIG_CHAR
BUS_OBJ_CD
CHAR
120
F1_MST_CONFIG_CHAR
CHAR_TYPE_CD
CHAR
32
F1_MST_CONFIG_CHAR
CHAR_VAL
CHAR
64
F1_MST_CONFIG_CHAR
CHAR_VAL_FK1
VARCHAR2
200
F1_MST_CONFIG_CHAR
CHAR_VAL_FK2
VARCHAR2
200
F1_MST_CONFIG_CHAR
CHAR_VAL_FK3
VARCHAR2
200
F1_MST_CONFIG_CHAR
CHAR_VAL_FK4
VARCHAR2
200
F1_MST_CONFIG_CHAR
CHAR_VAL_FK5
VARCHAR2
200
F1_MST_CONFIG_CHAR
CONFIG_PART_NAME
VARCHAR2
1016
F1_MST_CONFIG_CHAR
SEQ_NUM
NUMBER
22
F1_MST_CONFIG_CHAR
SRCH_CHAR_VAL
VARCHAR2
200
F1_MST_CONFIG_CHAR
VERSION
NUMBER
22
F1_PATCH_DETAILS
APPL_VERSION
VARCHAR2
240
F1_PATCH_DETAILS
BASE_REF_ID
VARCHAR2
240
F1_PATCH_DETAILS
EXT_PATCH_REF_ID
VARCHAR2
240
F1_PATCH_DETAILS
PATCH_CATEGORY
VARCHAR2
1016
F1_PATCH_DETAILS
PATCH_COMP_XFLG
VARCHAR2
120
F1_PATCH_DETAILS
PATCH_COPY_FLG
CHAR
16
F1_PATCH_DETAILS
PATCH_DESCR
VARCHAR2
1016
F1_PATCH_DETAILS
PATCH_ID
CHAR
48
F1_PATCH_DETAILS
PATCH_INSTALL_DTTM
DATE
7
F1_PATCH_DETAILS
PATCH_PROD_ID
VARCHAR2
120
F1_PATCH_DETAILS
PATCH_VERSION
VARCHAR2
240
F1_PATCH_DETAILS
RELATED_REF_ID
VARCHAR2
240
F1_PATCH_DETAILS
RELEASE_VER
VARCHAR2
400
F1_PATCH_DETAILS
VERSION
NUMBER
22
F1_PROC_PANEL
UI_MAP_CD
CHAR
120
F1_PROD_METRIC_SNPSHT
BO_STATUS_CD
CHAR
48
BO_XML_DATA_AREA
XMLTYPE
2000
BUS_OBJ_CD
CHAR
120
CRE_DTTM
DATE
7
METRIC_SNAPSHOT_ID
CHAR
48
PROD_METRIC_TYPE_CD
VARCHAR2
120
SNAPSHOT_XML_DATA_AREA
XMLTYPE
2000
STATUS_UPD_DTTM
DATE
7
VERSION
NUMBER
22
F1_PROD_METRIC_SNPSHT_K
ENV_ID
NUMBER
22
METRIC_SNAPSHOT_ID
CHAR
48
F1_PROD_METRIC_SNPSHT_VAL
EXT_PROD_METRIC
CHAR
144
METRIC_SNAPSHOT_ID
CHAR
48
METRIC_VALUE
VARCHAR2
1016
VERSION
NUMBER
22
F1_PROD_METRIC_TYPE
BO_STATUS_CD
CHAR
48
F1_PROD_METRIC_TYPE
BO_XML_DATA_AREA
XMLTYPE
2000
F1_PROD_METRIC_TYPE
BUS_OBJ_CD
CHAR
120
F1_PROD_METRIC_TYPE
OWNER_FLG
CHAR
16
F1_PROD_METRIC_TYPE
PROD_METRIC_TYPE_CD
VARCHAR2
120
F1_PROD_METRIC_TYPE
PROD_OFFERINGS
VARCHAR2
400
F1_PROD_METRIC_TYPE
SNAPSHOT_BO_CD
CHAR
120
F1_PROD_METRIC_TYPE
VERSION
NUMBER
22
F1_PROD_METRIC_TYPE_L
DESCR100
VARCHAR2
400
DESCRLONG
VARCHAR2
16000
LANGUAGE_CD
CHAR
12
OWNER_FLG
CHAR
16
PROD_METRIC_TYPE_CD
VARCHAR2
120
VERSION
NUMBER
22
F1_REDACTION_RULE
BUS_OBJ_CD
CHAR
120
F1_REDACTION_RULE
FLD_NAME
CHAR
120
F1_REDACTION_RULE
REDACT_FILTER_EXP
VARCHAR2
8000
F1_REDACTION_RULE
REDACT_FUNC_XFLG
VARCHAR2
120
F1_REDACTION_RULE
REDACT_REF_FLD
CHAR
120
F1_REDACTION_RULE
REDACT_RULE_CD
VARCHAR2
120
F1_REDACTION_RULE
REDACT_SRC_TYPE_FLG
CHAR
16
F1_REDACTION_RULE
REDACT_XPATH_EXP
VARCHAR2
8000
F1_REDACTION_RULE
TBL_NAME
CHAR
120
F1_REDACTION_RULE
VERSION
NUMBER
22
F1_REDACTION_RULE_L
DESCR100
VARCHAR2
400
F1_REDACTION_RULE_L
LANGUAGE_CD
CHAR
12
F1_REDACTION_RULE_L
REDACT_RULE_CD
VARCHAR2
120
F1_REDACTION_RULE_L
VERSION
NUMBER
22
F1_REQ_TYPE
OWNER_FLG
CHAR
16
F1_REQ_TYPE_L
OWNER_FLG
CHAR
16
F1_SIBSCH_TBLS_VW
SYSTEM_TBL_SW
CHAR
4
F1_SIBSCH_TBLS_VW
TBL_NAME
CHAR
120
F1_TAG
BO_DATA_AREA
CLOB
4000
F1_TAG
BUS_OBJ_CD
CHAR
120
F1_TAG
ENTITY_TAG
VARCHAR2
120
F1_TAG
ENTITY_TAG_CLASS_FLG
CHAR
16
F1_TAG
MAINT_OBJ_CD
CHAR
48
F1_TAG
OWNER_FLG
CHAR
16
F1_TAG
TAG_STATUS_FLG
CHAR
16
F1_TAG
VERSION
NUMBER
22
F1_TAGGED_ENTITY
ENTITY_TAG
VARCHAR2
120
F1_TAGGED_ENTITY
KEYS
VARCHAR2
800
F1_TAGGED_ENTITY
MAINT_OBJ_CD
CHAR
48
F1_TAGGED_ENTITY
OWNER_FLG
CHAR
16
F1_TAGGED_ENTITY
PK_VALUE1
VARCHAR2
1016
F1_TAGGED_ENTITY
PK_VALUE2
VARCHAR2
1016
F1_TAGGED_ENTITY
PK_VALUE3
VARCHAR2
1016
F1_TAGGED_ENTITY
PK_VALUE4
VARCHAR2
1016
F1_TAGGED_ENTITY
PK_VALUE5
VARCHAR2
1016
F1_TAGGED_ENTITY
REFERENCE_NAME
VARCHAR2
240
F1_TAGGED_ENTITY
VERSION
NUMBER
22
F1_TAG_CHAR
ADHOC_CHAR_VAL
VARCHAR2
1016
F1_TAG_CHAR
CHAR_TYPE_CD
CHAR
32
F1_TAG_CHAR
CHAR_VAL
CHAR
64
F1_TAG_CHAR
CHAR_VAL_FK1
VARCHAR2
200
F1_TAG_CHAR
CHAR_VAL_FK2
VARCHAR2
200
F1_TAG_CHAR
CHAR_VAL_FK3
VARCHAR2
200
F1_TAG_CHAR
CHAR_VAL_FK4
VARCHAR2
200
F1_TAG_CHAR
CHAR_VAL_FK5
VARCHAR2
200
F1_TAG_CHAR
ENTITY_TAG
VARCHAR2
120
F1_TAG_CHAR
OWNER_FLG
CHAR
16
F1_TAG_CHAR
SEQ_NUM
NUMBER
22
F1_TAG_CHAR
SRCH_CHAR_VAL
VARCHAR2
200
F1_TAG_CHAR
VERSION
NUMBER
22
F1_TAG_L
DESCR100
VARCHAR2
400
F1_TAG_L
DESCRLONG
VARCHAR2
16000
F1_TAG_L
ENTITY_TAG
VARCHAR2
120
F1_TAG_L
LANGUAGE_CD
CHAR
12
F1_TAG_L
OWNER_FLG
CHAR
16
F1_TAG_L
VERSION
NUMBER
22
F1_TREE
APPLY_HEADER_STYLE_FLG
CHAR
16
F1_TREE
BUS_OBJ_CD
CHAR
120
F1_TREE
OWNER_FLG
CHAR
16
F1_TREE
TREE_CD
CHAR
120
F1_TREE
VERSION
NUMBER
22
F1_TREE_L
DESCR100
VARCHAR2
400
F1_TREE_L
LANGUAGE_CD
CHAR
12
F1_TREE_L
OWNER_FLG
CHAR
16
F1_TREE_L
TREE_CD
CHAR
120
F1_TREE_L
VERSION
NUMBER
22
F1_TREE_NODE
BROADCAST_NODE_FLG
CHAR
16
F1_TREE_NODE
CONTEXT_MENU_NAME
CHAR
120
F1_TREE_NODE
CTXT_MENU_USAGE_FLG
CHAR
16
F1_TREE_NODE
DISP_ICON_CD
CHAR
48
F1_TREE_NODE
INITIALLY_EXPAND_FLG
CHAR
16
F1_TREE_NODE
NODE_NAME
CHAR
120
F1_TREE_NODE
NODE_NAVIGATION_FLG
CHAR
16
F1_TREE_NODE
NODE_TEXT_FORMAT
VARCHAR2
8000
F1_TREE_NODE
NODE_TEXT_LABEL
CHAR
120
F1_TREE_NODE
OWNER_FLG
CHAR
16
F1_TREE_NODE
PARENT_NODE_NAME
CHAR
120
F1_TREE_NODE
SEQNO
NUMBER
22
F1_TREE_NODE
TREE_CD
CHAR
120
F1_TREE_NODE
VERSION
NUMBER
22
F1_TREE_NODE_ALG
ALG_CD
CHAR
48
F1_TREE_NODE_ALG
NODE_NAME
CHAR
120
F1_TREE_NODE_ALG
OWNER_FLG
CHAR
16
F1_TREE_NODE_ALG
SEQ_NUM
NUMBER
22
F1_TREE_NODE_ALG
TREE_CD
CHAR
120
F1_TREE_NODE_ALG
TREE_NODE_SEVT_FLG
CHAR
16
F1_TREE_NODE_ALG
VERSION
NUMBER
22
F1_TREE_NODE_L
DESCR100
VARCHAR2
400
F1_TREE_NODE_L
LANGUAGE_CD
CHAR
12
F1_TREE_NODE_L
NODE_NAME
CHAR
120
F1_TREE_NODE_L
OWNER_FLG
CHAR
16
F1_TREE_NODE_L
TREE_CD
CHAR
120
F1_TREE_NODE_L
VERSION
NUMBER
22
SC_APP_SERVICE_L
DESCRLONG
VARCHAR2
16000
SC_USER
DASHBOARD_LOC_FLG
CHAR
16
SC_USER
DASHBOARD_STATE_FLG
CHAR
16
SEC_INVENTORY
ENCRYPTED_BYTES
RAW
2000
SEC_INVENTORY
ENCRYPTION_ALG
VARCHAR2
120
SEC_INVENTORY
ENC_KEY_NAME
VARCHAR2
800
SEC_INVENTORY
SALT
RAW
2000
SEC_INVENTORY
SECRET_NAME
VARCHAR2
800
SEC_INVENTORY
VERIFICATION_HASH
RAW
2000
SEC_INVENTORY
VERIFICATION_HASH_ALG
VARCHAR2
120
Dropped Columns
Table_Name
Column_Name
From
To
CI_ALG_PARM
ALG_PARM_VAL
VARCHAR2
8000
CI_CNV_DUP_KEY
CX_ID
CHAR
56
CI_CNV_KEY_TMP
CI_ID
CHAR
56
CI_CNV_KEY_TMP
CX_ID
CHAR
56
CI_CNV_KEY_TMP
INIT_ID
VARCHAR2
56
CI_ZONE_PRM
ZONE_PARM_VAL
VARCHAR2
16000
BUS_OBJ_CD
CHAR
120
D1_CONTACT_EMAIL
EMAIL_VALUE
VARCHAR2
280
D1_INBOUND_COMM_VW
D1_SP_ID
VARCHAR2
48
D1_INBOUND_COMM_VW
POSTAL
VARCHAR2
48
D1_OUTBOUND_COMM_VW
D1_SP_ID
VARCHAR2
48
D1_OUTBOUND_COMM_VW
POSTAL
VARCHAR2
48
F1_CRYPTO_KEY
PUBLIC_KEY
VARCHAR2
8000
F1_CRYPTO_KEY_RING_LINK
EXT_KEY_RING_CD
CHAR
120
INT_KEY_RING_CD
CHAR
120
VERSION
NUMBER
22
F1_PROC_PANEL
UI_MAP_CD
VARCHAR2
120
