Creating an Example WebLogic Domain
This section provides the steps to create example weblogic domains of OSB and SOA which are created under osbapp and soaapp. Before executing the below scripts, Repository Creation Utility (RCU) should be used to create schemas required for the respective domains and the values of prefix & password used for creation of schemas should be specified in the configuration menu.
Oracle does recommend the usage of example domains for production use.
Creating an OSB Example Domain
Follow the procedure below to create an OSB example domain:
1. Ensure that values are set for the following menu items.
Please refer to Appendix B - “8. OSB Configuration” for more information.
• OSB Port Number
• OSB SSL Port Number
• JDBC URL for database
• OSB Service Table Schema Name
• OSB Service Table Schema Password
2. Run the following commands:
Linux:
cd $SPLEBASE/bin
./createDomain.sh –t OSB
Windows
cd %SPLEBASE%/bin
./createDomain.cmd –t OSB
Creating a SOA Example Domain
Follow the procedure below to create a SOA example domain:
Refer to SOA Configuration for more information.
• SOA Port Number
• SOA SSL Port Number
• SOA Service Table Schema Name
• SOA Service Table Schema Password
Linux:
cd $SPLEBASE/bin
./createDomain.sh –t SOA
Windows
cd %SPLEBASE%/bin
./createDomain.cmd –t SOA
