Deploying Oracle Service Bus Adapters on SSL
This section describes steps to deploy Oracle Service Bus (OSB) on SSL.
1. Set the OSB SSL Port Number and configure Menu 60 should be configured appropriately. Refer to Appendix B Installation and Configuration Worksheets for detailed info.
• Enable OSB SSL Port
• OSB Trust Keystore Type
• OSB Trust Keystore File Type
2. Run the following commands when using Custom trust store:
Note: Replace <adapter> in the below commands with the respective adapter name i.e (LG, D4, MV90, D6, D7, D8, DG).
UNIX
$SPLEBASE/product/apache-ant/bin/ant -buildfile deploy-
osb_<adapter>.xml -Dadmin.user=<ADMIN_USER> -Dadmin.password=<OSB_ADMIN_PASSWORD> -Douaf.user=<JMS_USER> -Douaf.password=<JMS_PASSWORD> -Dprocessing.archive=true -Dosb.user=<OSB_USER> -Dosb.password=<OSB_PASSWORD> -Douaf.filter.user=<JMS_USER> -Douaf.filter.password=<JMS_PASSWORD> -
Dosb.keystore.passphrase=<passphrase_of_truststore_for_osb_deployment>
Note: Use the following command if this is an upgrade from a previous version:
cd $SPLEBASE/osbapp
$SPLEBASE/product/apache-ant/bin/ant -buildfile deploy-osb_<adapter>.xml
update_osb -Dadmin.user=<ADMIN_USER> -Dadmin.password=<OSB_ADMIN_PASSWORD> -Douaf.user=<JMS_USER> -Douaf.password=<JMS_PASSWORD> -Dprocessing.archive=true -Dosb.user=<OSB_USER> -Dosb.password=<OSB_PASSWORD> -Douaf.filter.user=<JMS_USER> -Douaf.filter.password=<JMS_PASSWORD> - Dosb.keystore.passphrase=<passphrase_of_ truststore _for_osb_deployment>
This will not override any OSB custom changes
Windows
%SPLEBASE%\product\apache-ant\bin\ant -buildfile deploy-
osb_<adapter>.xml -Dadmin.user=<ADMIN_USER> -Dadmin.password=<OSB_ADMIN_PASSWORD> -Douaf.user=<JMS_USER> -Douaf.password=<JMS_PASSWORD> -Dprocessing.archive=true -Dosb.user=<OSB_USER> -Dosb.password=<OSB_PASSWORD> -Douaf.filter.user=<JMS_USER> -Douaf.filter.password=<JMS_PASSWORD> - Dosb.keystore.passphrase=<passphrase_of_ truststore _for_osb_deployment>
cd %SPLEBASE%/osbapp
%SPLEBASE%/product/apache-ant/bin/ant -buildfile deploy-osb_<adapter>.xml
3. The following commands are required when using Demo trust store:
UNIX
cd $SPLEBASE/osbapp
$SPLEBASE/product/apache-ant/bin/ant -buildfile deploy- osb_<adapter>.xml -Dadmin.user=<ADMIN_USER>
cd $SPLEBASE/osbapp
This will not override any OSB custom changes.
Windows
cd %SPLEBASE%\osbapp
%SPLEBASE%\product\apache-ant\bin\ant -buildfile deploy- osb_<adapter>.xml -Dadmin.user=<ADMIN_USER> -Dadmin.password=<OSB_ADMIN_PASSWORD> -Douaf.user=<JMS_USER> -Douaf.password=<JMS_PASSWORD> -Dprocessing.archive=true -Dosb.user=<OSB_USER> -Dosb.password=<OSB_PASSWORD> -Douaf.filter.user=<JMS_USER> -Douaf.filter.password=<JMS_PASSWORD>
Note: Use the following command if this is an upgrade from a previous version.
%SPLEBASE%/product/apache-ant/bin/ant -buildfile deploy- osb_<adapter>.xml
