Before You Install
Visit
My Oracle Support for up-to-date additional information about installing Oracle Utilities Smart Grid Gateway.
WebLogic Native Installation
With Oracle Utilities Application Framework 25.4, a WebLogic native installation is required. See the
Oracle WebLogic Configuration Guide for Oracle Utilities Framework document on
My Oracle Support for more information.
Application Server Clustering
If you are considering application server clustering, refer to the
My Oracle Support.
For additional information about WebLogic clustering, refer to the
Fusion Middleware Using Clusters for Oracle WebLogic Server documentation.
Directory Names
Directory cannot contain whitespace characters.
Prerequisite Software List
Before you install Oracle Utilities Smart Grid Gateway, you must install prerequisite software.
Refer to the respective installation documentation of the software for instructions on downloading and installing.
Prerequisite Software for Database Server
The prerequisite software for the database component of Oracle Utilities Smart Grid Gateway is as follows:
• Oracle Database Server 19c: This is required for installing the database component of the Oracle Utilities Smart Grid Gateway product. The following version of the database server is supported:
• Oracle Database Enterprise Edition
Note: Oracle Database Enterprise Edition and the Partitioning and Advanced Compression options are strongly recommended in all situations.
Prerequisite Software for Application Server
The prerequisite software for the Oracle Utilities Smart Grid Gateway application component is:
• Oracle Database Client 19.x (Runtime or Administrator client installation type)
• Oracle Java SE Development Kit 17.0.x (Windows and Linux platforms only) 64-bit
• Oracle WebLogic 14.1.2
Oracle Security Fix Updates
It is recommended that you keep the Oracle pre-requisite software up to date with the latest security fixes provided by Oracle.
Web Browser Requirements
The web browsers listed below are supported when used on each of the operating systems indicated:
