Software and Hardware Considerations
There are many factors that can influence software and hardware decisions. For example, your system may have to satisfy specific performance, availability, or scalability requirements, or to support running in a language other than English. These business requirements, together with the chosen system architecture, should be used in initial software and hardware planning.
Some of the questions that you should answer before beginning the installation include:
• On which hardware platform and operating system will Oracle Utilities Smart Grid Gateway be deployed?
• On which web server product will Oracle Utilities Smart Grid Gateway deploy?
• On which database product will Oracle Utilities Smart Grid Gateway deploy?
• Do you plan to deploy multiple Oracle Utilities Smart Grid Gateway instances on the same physical server?
• How do you plan to deploy Oracle Utilities Smart Grid Gateway?
• Web/application/database on the same physical server
• Web/application on one server and database on separate server
• Each component on its own server
For detailed descriptions of various deployment architecture choices that may aid in planning, refer to the Oracle Utilities Application Framework Architecture Guidelines (Article ID 807068.1) document available on My Oracle Support.
The final hardware and software decisions must comply with the specific requirements of Oracle Utilities Smart Grid Gateway.
