Before You Upgrade
Review the list of operating system, application server and database server combinations that this version of Oracle Utilities Smart Grid Gateway is certified to operate on. The list is provided in the Supported Platforms and Hardware Requirements chapter.
For further assistance, contact My Oracle Support before you upgrade.
Note: If you are upgrading a previously installed application server, it is recommended that you make a backup before you start the upgrade procedure. The upgrade installation will remove your existing environment including your configurations.
