Operating Systems and Application Servers
This section details the operating system and application server combinations on which this version of Oracle Utilities Smart Grid Gateway is supported.
Application Server Operating Systems
• Oracle Linux 8.x or 9.x (64-bit) for x86_64
• Windows 11 Version x and Windows Server 2022 (for OUAF SDK use only)
Prerequisite Application Server Software
• Oracle Database Client 19c
• Oracle Java SE Development Kit 17.0.x (Windows and Linux platforms only)
Notes:
Oracle Linux is 100% user space-compatible with Red Hat Enterprise Linux, therefore, Oracle Utilities Application Framework is also supported on Red Hat Enterprise Linux.
Refer to the Oracle Utilities Application Framework Database Administrator’s Guide for information on Oracle database server requirements.
Refer to the Certification Matrix for Oracle Utilities Products (Document ID 1454143.1) on My Oracle Support to determine if support for newer versions of the listed products have been added.
Please note the following:
• Version numbers marked with a “+” are the MINIMUM version supported. That version and all future 4th digit updates will be supported.
Example: Oracle 19c means that 19 and any higher versions of Oracle 19 are supported.
• An “x” indicates that any version of the digit designed by the “x” is supported.
Example: Linux 8.x indicates that any version of Linux 8 (8.0, 8.1, 8.2 etc) will be supported.
Windows Server
• Windows Server is not supported for Production environments. Wherever Windows Server is referenced within this guide, it is supported for Test or Development environments only.
WebLogic Server
• Oracle WebLogic Server (Fusion Middleware Infrastructure) 14.1.2
• Customers must download Oracle WebLogic Server from the Oracle Software Delivery Cloud.
Oracle Database Server
Prerequisite database server software (on any vendor supported platform where x is vendor supported version):
• Oracle 19c (64-bit) on-premises and cloud (ADB)
Oracle VM Support
This version of Oracle Utilities Smart Grid Gateway is supported on Oracle VM Server for x86 for supported releases of Oracle Linux and Microsoft Windows operating systems.
Refer to My Oracle Support knowledge base article 249212.1 for Oracle’s support policy on VMWare.
SDK - Supported Combinations
Refer to the SDK documentation for supported platforms and installation instructions.
Hardware and Web Browser Requirements
This section oulines the hardware and web browser requirements for Oracle Utilities Smart Grid Gateway.
Client Side Hardware Requirements
The client side hardware requirements for Oracle Utilities Smart Grid Gateway are as follows:.
Configuration
Processor
Memory (RAM)
Storage
Monitor Display
Minimum
2 gigahertz (GHz) or?faster with 2 or more cores *
8 GB **
128 GB or higher ***
Refer to the Redwood Large resolution (currently 1024px).
Recommended
3 gigahertz (GHz) or?faster with 2 or more cores *
16 GB **
250 GB or higher ***
* or comparable processor
** more RAM may be needed for more graphic intensive application features, such as Oracle Utilities Work and Asset Management’s GIS Viewer or CM Portals that contain numerous graphs.
*** to support browser caching
Note that the hardware requirements above are based on running the application only, and without any additional software running concurrently. If your client setup requires other software running, please adjust the requirements to account for them.
The web browsers listed below are supported when used on each of the operating systems indicated:
Browser
Windows Operating System
Microsoft Edge for Business 81+ (Edge Chromium)
Microsoft Windows 11 Version x 64-bit
Mozilla Firefox ESR 128
Google Chrome Enterprise 81+
Apple Mobile Safari
Apple iPad iOS 18.x
