Component  | Functional Area  | Description  |
F1-Algorithm  | Admin   | Used to create, read, update, and delete Algorithm via a Web service. After creation, the CRUD operations can be performed through these components against the F1-AlgorithmPhysicalBO business object.  |
F1-BatchContol  | Admin  | Used to create, read, or update a ‘Batch Control’ via a Web service.  After creation, the CRUD operations can be performed through these components against the F1-BatchContolMO business object.  |
F1-Country   | Admin  | Used to create, read, or update a ‘Country’ via a Web service. After creation, the CRUD operations can be performed through these components against the F1-COUNTRY business object.  |
F1-DisplayProfile  | Admin  | Used to create, read, or update a ‘DisplayProfile via a Web service.  After creation, the CRUD operations can be performed through these components against the F1-DisplayProfilePhysicalBO business object.  |
F1-ExternalSystem  | Admin  | Used to create, read, or update an ‘ExternalSystem’ via a Web service.  After creation, the CRUD operations can be performed through these components against the F1-ExternalSystemPhysicalBO business object.  |
F1-FeatureConfig  | Admin  | Used to create, read, or update a ‘FeatureConfig’ via a Web service.  After creation, the CRUD operations can be performed through these components against the F1-FeatureConfigPhysicalBO business object.   |
F1-TimeZone  | Admin  | Used to create, read, or update a ‘TimeZone’ via a Web service.  After creation, the CRUD operations can be performed through these components against the F1-TimeZonePhysicalBO business object.  |
F1-User  | Admin  | Used to create, read, or update a ‘User’ via a Web service. After creation, the CRUD operations can be performed through these components against the F1-UserPhysicalBO business object.  |
F1-UserGroup  | Admin  | Used to create, read, or update a ‘UserGroup’ via a Web service. After creation, the CRUD operations can be performed through these components against the F1-UserGroupPhysicalBO business object.  |
F1-WorkCalendar  | Admin  | Used to create, read, or update a ‘WorkCalendar’ via a Web service.  After the creation, the CRUD operations can be performed through these components against the F1-WorkCalendarPhysicalBO business object.  |
F1-ToDoRole   | ToDo  | Used to create, read, or update a ‘ToDoRole’ via a Web service.  After creation, the CRUD operations can be performed through these components against the F1-ToDoRolePhysical business object.  |
F1-ToDoType   | ToDo  | Used to create, read, or update a ‘ToDoType’ via a Web service.  After creation, the CRUD operations can be performed through these components against the F1-ToDoTypePhysicalBO business object.  |
F1-BatchSubmission  | Batch  | Used to run or retrieve the Batch submission status via a Web service. After creation, execute the batch job and retrieve the batch job running status against the F1-BatchJob business object.  |
F1-ToDoEntryAdd  | ToDo  | Used to create a To Do Entry via a Web service. After creation, add To Do entries through these component against the F1-AddToDoEntry business service.  |
F1-ToDoEntryRead   | ToDo  | Used to retrieve a To Do Entry via a Web service. After creation, retrieve the To Do Entry through this component against the F1-MaintainToDoEntry business service.  |
F1-ToDoEntryUpdate  | ToDo  | Used to update a To Do Entry via a Web service. After creation, retrieve the To Do Entry through this component against the F1-UpdateToDoEntry business service.  |
F1-ToDoEntryComplete  | ToDo  | Used to complete a To Do Entry via a Web service. After creation, complete the To Do Entry through this component against the F1-CompleteToDoEntry business service.  |
F1-SendResultsMail  | Admin  | Parses the results and generates the email. This component sends the test executions results to the configured email ID.  |
F1-OutboundMsgType  | Admin  | Component for Outbound Message type.   |
F1-WaitTime  | Admin  | Used to wait for some time to complete certain task. The wait time is in specified in minutes.  |
F1-ImportAndDeployBundle   | Admin  | Reads the bundle content from the attachment and applies the bundle. This component returns the status and ID of the bundle objects in OUAF.  |
F1-InstallationOption  | Admin  | Enables edge applications to set the installation options values in OUAF.  |
F1-OutboundMessageType  | Admin  | Adds/reads the outbound message type.  |
F1-XAISender  | Admin  | Adds/reads the XAI sender.  |
F1-FileStorage  | Admin  | Used for file storage configuration.   |
F1-GeographicType  | Admin  | Used to add Geographic Type.   |
F1-CopyEntity  | Admin  | Creates a new entity as a copy of another entity that its key is system generated.   |
F1-GenericDataExplorer  | Admin  | Runs a data explorer query zone provided as input. The query supports up to 10 optional filters and returns up to 10 columns for each result query row.   |
F1-BatchCompletionStatus  | Batch  | Takes the Batch ID as input and verifies if a given batch is complete or not within the time frame.   |
F1-BatchRTStatistics  | Batch  | Used to get the batch run and thread statistics using Batch Job ID.   |
F1-BatchRunDetails  | Batch  | Gives the batch run details like message shown in the batch run tree.   |
F1-ContextualInsightType  | General  | Used to Add/Read/Update/Delete Contextual Insight Type.   |
F1-InsightGroup  | General  | Used to Add/Read/Update/Delete Insight Group.   |
F1-Login  | Admin  | Login to the environment through UI  |
F1-Quit  | Admin  | Quit Browser  |
F1-XAISubmission  | Admin  | Used for XAI submission through UI  |
F1-VerifyAppViewer  | Admin  | Used to verify App Viewer  |
F1-VerifyHelp  | Admin  | Used to verify Help  |
F1-Logout  | ToDo  | Logout from application through UI  |
