Flow Run Summary
The Flow Run Summary service provides summary file for the flow run in Oracle Utilities Testing Accelerator.
Endpoint
>/rest/summary/report
Curl Command for Flow Run Summary
curl -X POST \
'https://<hostname>:<port>/rest/summary/report?type=flow&flowName=x' \
-H 'accept: application/xml' \
-H 'authorization: Basic <Base64 encoded username & password>' \
-H 'authorization:Basic <Base64 encoded username & password>' \
-d '["<flow execution id>"]'
Parameters
• <hostname>: Oracle Utilities Testing Accelerator application host name
• <port>: Oracle Utilities Testing Accelerator application port
• < token>: Authentication token from the steps mentioned in pre-requisites above
• <flow execution id>: Flow execution ID of the flow for which the summary is being requested
Example
Flow Run Summary
curl -X POST \
-H 'authorization: Basic bXJpbmFsOk9yYWNsZTEyMw==' \
-H 'content-type: application/json' \
-d '["2507"]'
The server responds with a HTML summary file as response upon receiving this request.
