SOAP UI
This method is an alternative to the other methods mentioned above if the user is familiar with SOAP UI.
To identify the requisite fields using SOAP UI:
1. Login to the application.
2. Navigate to the page where the test data has to added. Add the data in the respective fields.
For example: The figure below shows the
Case page where
Characteristics Type and
Characteristic Value are added in the
Characteristics section.
![](../WACS-REF-GUIDE-23A/images/SOAP_UI_Step_2.jpg)
3. On the SOAP UI, perform a Read using the data that has been added on the
Case page (in step 2). The result is displayed in the right pane.
![](../WACS-REF-GUIDE-23A/images/SOAP_UI_Step_3.jpg)
4. Copy the values and paste them in the respective fields on the flow.
For example: COMMENT and TEST CHARTYPE INFO are the values for characteristicType and adhocCharacteristicValue fields.
Note: Not all fields populated on the SOAP response needs to be populated on the flow. (For example: version, info, other type of description, etc).
![](../WACS-REF-GUIDE-23A/images/SOAP_UI_Step_4.jpg)
5. Click Save to save the data.
