Debug Mode in the Application
The debug mode enables users to check the field mapping on a given maintenance page. This is actually the easiest among the different possible ways; however some clients may have system restriction (such as access restriction) on using debug mode.
To enter test data in the requisite fields using the debug method:
1. Login to the Oracle Utilities Billing Cloud Service application in the ‘debug’ mode.
2. Before clicking the Debug mode switch, make sure to navigate to the target page first.
Example: Person maintenance page
![Shows the target page. Shows the target page.](../BCS-REFERENCE-GUIDE-23B/images/Debug_Switch.jpg)
3. Perform the required action and click Save.
For example: The figure below shows adding a person (person name, person phone, person contacts, Person IDs, etc)
![Shows adding a person. Shows adding a person.](../BCS-REFERENCE-GUIDE-23B/images/Add_Person.jpg)
The schema window showing the populated values is displayed.
![Shows the schema window with populated values. Shows the schema window with populated values.](../BCS-REFERENCE-GUIDE-23B/images/Schema_Popup.jpg)
4. Navigate to the Business Object or Business Service lookup window for the requisite field. For example: In the figure below, ENTITY_NAME is named as entityName.
![](../BCS-REFERENCE-GUIDE-23B/images/Business_Object_Look.jpg)
5. In the flow, search for the requisite field and enter the component test data.
![](../BCS-REFERENCE-GUIDE-23B/images/Entering_Test_Data.jpg)
6. Click Save to save the test data.
