IE Development Tool Bar
The IE Development tool bar, available in IE11, enables users to inspect the page and its field mapping. It is on a 1:1 basis, meaning one inspect = one field.
To enter test data in the requisite fields using the IE Development tool bar, follow these steps:
1. Login to Oracle Utilities Rate Cloud Service using Internet Explorer 11.
2. Navigate to the page where the requisite field needs to be updated with data.
For example: The figure below shows the
Account page where the
Characteristic Value field on the
Characteristics tab needs to be updated.
![](../RCS-REFERENCE-GUIDE-23B/images/IE_Development_Tool_Bar_Step_2.jpg)
3. Press
F12. The browser displays the F12 developer tools that help in building and debugging web pages.
![](../RCS-REFERENCE-GUIDE-23B/images/IE_Development_Tool_Bar_Step_3.jpg)
4. On the F12 tools menu, click the
DOM Explorer tab, and then click the
Select element icon.
![](../RCS-REFERENCE-GUIDE-23B/images/IE_Development_Tool_Bar_Step_4.jpg)
5. On the application page, click the field for which you need to enter the data. The DOM Explorer shows the HTML for the selected field.
For example: Click the
Account page. The DOM Explorer shows the
ID of that field.
![](../RCS-REFERENCE-GUIDE-23B/images/IE_Development_Tool_Bar_Step_5.jpg)
6. On the object lookup window, search the requisite field.
For example: Search for CHAR_VAL_FK1.
![](../RCS-REFERENCE-GUIDE-23B/images/IE_Development_Tool_Bar_Step_6.jpg)
7. In the flow, add the necessary data into the field.
![](../RCS-REFERENCE-GUIDE-23B/images/IE_Development_Tool_Bar_Step_7.jpg)
8. Click Save to save the data.
