Flow Run Analytics
The Flow Run Analytics service provides analytics for the flows run in Oracle Utilities Testing Accelerator by a specific user for a given period.
Endpoint
>/rest/analytics/user
Curl Command for Flow Run Analytics
curl -i -k -X GET -k 'https://<hostname>:<port>/rest/analytics/user/<username>/flowExecutionAnalytics/from/<fromDate>/to/<toDate>' -H 'authorization: Basic <Base64 encoded username & password>'
Parameters
<hostname>: OUTA application host name
<port>: OUTA application port
<access token>: Authentication token from the step in pre-requisites above
<username>: Name of the user who executed the flow(s)
<fromDate>: The start date to query for analytics - format DD-MON-YY (example: 10-JAN-20)
<toDate>: The end date to query for analytics - format DD-MON-YY (example: 20-JAN-20)
Example
Flow Run Analytics
curl -i -k -X GET -k https://<hostname>:<port>/rest/analytics/user/admin/flowExecutionAnalytics/from/01-JAN-20/to/15-JAN-20 -H 'authorization: basic 62593bbd-b057-4f38-8a3e-5915d4ab559f'
Once a flow set run is triggered, the service responds with a response as follows.
{"totalFlowsRanByUser":50,"totalFlowsRanByUserSuccess":48,"totalFlowsRanByUserFailure":2,"totalFlowsRanByUserRunning":0}'
