Copying Components
The components delivered can be customized; however, modifying the existing components is not a good practice.
A component can be extended by making its copy and saving it with a different name prefixed and tagged by CM, and then adding or modifying the metadata or key words as follows:
1. Right-click an existing component and select Copy Component.
2. Select and right-click a module. It is recommended to create a new module named “Custom Components” to hold any custom components.
3. From the context menu, select Paste Component.
If the component name already exists in the module, then a warning will be displayed followed with a prompt for providing a new name to the component.
4. Click Save. The component is copied successfully.
