Creating a Test Plan
To create a test plan:
1. Login to the application.
2. Navigate to the Test Planning menu.
3. Click New under the Test Plans section.
4. Provide the Test Plan Name (a unique identifier for a test plan).
5. Provide a Short Description and a Long Description for the test plan.
6. Select the type of the test plan from the Type drop-down list. It helps to differentiate if the test plan pertains to new feature testing, sanity testing or other types of testing. You can also use it when searching for a test plan.
7. Click Create.
The test plan will be created and displayed in the Test Plan page. The new test plan will be in the “Planning” stage.
