Flow Export Tool
This feature is used to export one or more flows to another environment. Note that only flows in “Approved” state can be exported.
To export a flow:
1. Login to the application.
2. Navigate to the Tools tab.
3. Click Export Flows in the left pane.
4. Select the Release, Portfolio, Product, Flow Name, Tags (example: CM) and Owner Flag as required.
5. Click Export.
A prompt appears on the screen to open or save the generated zip file “flow.zip”.
6. Click Save to download the zip file.
The flow has been exported as a .zip file.
