WSVALIDATELIB
Use the WSVALIDATELIB function library to validate the test components (referred to as verification points) in the components. The library covers validation routines for string and XML elements in the returned response XML. The function automatically fails or passes a flow run subject to the satisfaction of the specified condition.
This section provides a list of functions in the library, along with the usage details.
elementListNotNull
Verifies if all the elements with the specified xpath in response are not null. The xpath to be verified needs to be provided in the Logical Name column in the pre/post validations sections. If the value is null, this function validation will fail the flow run.
Example:
elementListNotNull(String xPath)
elementNotNull(contact/mobileNumber)
Input Parameters:
xPath - xpath of the element whose value needs to be checked.
Return Type: void
elementListNull
Verifies if all the elements in response with the specified xpath are null. The xpath to be verified needs to be provided in the Logical Name column in the pre/post validations sections. If the value is NOT null, this function validation will fail the flow run.
Usage:
elementListNull(String xPath) elementNotNull(contact/mobileNumber)
Input Parameters:
xPath- xpath of the element whose value needs to be checked.
Return Type: void
validateXpathOccurrenceCount
Verifies if the specified xpath occurs the specified number of times in the response. The xpath to be verified needs to be provided in the Logical Name column in the pre/post validations sections. The function counts the number of occurrences of the xpath and will fail the flow run, if the count in the response doesn't match the specified number. The expected number of occurrences should be specified in the Value1 column.
Usage:
validateXpathOccurenceCount (String xpath,String expectedCount)
Example:
validateXpathOccurenceCount(contact/mobileNumber,20)
Input Parameters:
xpath - xpath of the element whose occurrence count needs to be checked.
expectedCount - the expected count of occurrences of the element
Return Type: void
elementNotNull
Verifies if the specified element in response is null. The xpath to be verified needs to be provided in the Logical Name column in the pre/post validations sections. This function fails the flow run if the specified element is found to be null in the response.
Usage:
elementNotNull(String xpath)
Example:
elementNotNull(mobileNumber)
Input Parameters:
xpath - xpath of the element whose value needs to be checked.
Return Type: void
elementIsNull
Verifies if the specified element in response is not null.
Usage:
elementIsNull (String xpath)
Example:
elementIsNull (mobileNumber)
Input Parameters:
Xpath - xpath of the element whose value needs to be checked.
Return Type: void
elementValueEquals
Verifies if the specified element value in response is equal to the provided value.
Usage:
elementValueEquals(String xpath, String expectedValue)
Example:
elementValueEquals(mobileNumber, "1234567890")
Input Parameters:
expectedValue - the expected value to be compared to for validation
Return Type: void
elementValueNotEquals
Verifies if the specified element value in response is not equal to the provided value.
Usage:
elementValueNotEquals(String xpath, String expectedValue)
Example:
elementValueNotEquals (mobileNumber, "1234567890")
Input Parameters:
Return Type: void
elementValueGreaterThan
Verifies if the specified element value in response is greater than the provided value.
Usage:
elementValueGreaterThan(String xpath, String valueToCompare)
Example:
elementValueGreaterThan("count","5")
Input Parameters:
valueToCompare - the expected value to be compared to for validation
Return Type: void
elementValueGreaterThanEqualTo
Verifies if the specified element value in response is greater than or equal to the provided value.
Example:
elementValueGreaterThanEqualTo(String responseTag,String valueToCompare)
elementValueGreaterThanEqualTo("totalRecords", "50")
Input Parameters:
Return Type: void
elementValueLesserThan
Verifies if the specified element value in response is less than the provided value.
Usage:
elementValueLesserThan(String xpath,String valueToCompare)
Example:
elementValueLesserThan ("counter", "50")
Input Parameters:
Return Type: void
elementValueLesserThanEqualTo
Verifies if the specified element value in response is less than or equal to the provided value.
Example:
elementValueLesserThanEqualTo(String xpath,String valueToCompare)
Usage:
elementValueLesserThanEqualTo ("attempts", "10")
Input Parameters:
Return Type: void
elementContains
Verifies if the specified element is available in the response.
Usage:
elementContains(String xpath,String valueToBeChecked)
Example:
elementContains("batchName", "F1-BILLING)
Input Parameters:
valueToBeChecked - the expected value to be compared to for validation
Return Type: void
elementNotContains
Verifies if the specified element is not available in the response.
Usage:
elementNotContains(String xpath, String valueToBeChecked)
Example:
elementNotContains ("description", "billing")
Input Parameters:
Return Type: void
reponseNotContains
Verifies if the specified value or element is not available in the response.
Usage:
reponseNotContains(String value)
Example:
reponseNotContains("Failed")
Input Parameters:
value - the value to be compared to for validation
Return Type: void
responseContains
Verifies if the specified value or element is available in the response.
Usage:
responseContains(String value)
Example:
responseContains("Exception")
Input Parameters:
Return Type: void
