IE Development Tool Bar
The IE Development tool bar, available in IE11, enables users to inspect the page and its field mapping. It is on a 1:1 basis, meaning one inspect = one field.
To enter test data in the requisite fields using the IE Development tool bar:
1. Login to Oracle Utilities Billing Cloud Service using Internet Explorer 11.
2. Navigate to the page where the requisite field needs to be updated with data.
Example: The figure below shows the
Account page where the
Characteristic Value field on the
Characteristics tab needs to be updated.
3. Press
F12. The browser displays the F12 developer tools that help in building and debugging web pages.
4. On the F12 tools menu, click the
DOM Explorer tab, and then click the
Select element icon.
5. On the application page, click the field for which you need to enter the data. The DOM Explorer shows the HTML for the selected field.
Example: Click the
Account page. The DOM Explorer shows the
ID of that field.
6. On the object lookup window, search the requisite field.
Example: Search for CHAR_VAL_FK1.
7. In the flow, add the necessary data into the field.
8. Click Save to save the data.
