Debug Mode in the Application
The debug mode enables users to check the field mapping on a given maintenance page. This is actually the easiest among the different possible ways; however some clients may have system restriction (such as access restriction) on using debug mode.
To enter test data in the requisite fields using the debug method:
1. Login to the Oracle Utilities Customer Cloud Service application in the ‘debug’ mode.
2. Before clicking the Debug mode switch ensure to navigate first to the target page.
Example: Person maintenance page
![Login to the Oracle Utilities Customer Cloud Service application in the ‘debug’ mode. Login to the Oracle Utilities Customer Cloud Service application in the ‘debug’ mode.](../UTA-CCS-REF-CLOUD/images/Debug_Switch.jpg)
3. Perform the required action. Click Save.
Example: The figure below shows adding a person (person name, person phone, person contacts, Person IDs, etc)
![This figure shows adding a person (person name, person phone, person contacts, Person IDs, etc) This figure shows adding a person (person name, person phone, person contacts, Person IDs, etc)](../UTA-CCS-REF-CLOUD/images/Add_Person.jpg)
The schema window showing the populated values is displayed.
![This figure shows the schema populated values. This figure shows the schema populated values.](../UTA-CCS-REF-CLOUD/images/Schema_Popup.jpg)
4. Navigate to the Business Object or Business Service look up window for the requisite field.
Example: In the figure below, ENTITY_NAME is named as entityName.
![This figure shows how to navigate to the Business Object or Business Service look up window for the requisite field. This figure shows how to navigate to the Business Object or Business Service look up window for the requisite field.](../UTA-CCS-REF-CLOUD/images/Business_Object_Look.jpg)
5. In the flow, search for the requisite field and enter the component test data.
![This figure shows searching for the requisite field and entering the component test data. This figure shows searching for the requisite field and entering the component test data.](../UTA-CCS-REF-CLOUD/images/Entering_Test_Data.jpg)
6. Click Save to save the test data.
