Provider | Component | Version | License Information |
The Apache Software Foundation | poi-ooxml-schemas | 4.1.2 | Copyright © 2002-2023 The Apache Software Foundation Licensed under the Apache License, Version 2.0 (the "License"); you may not use this file except in compliance with the License. You may obtain a copy of the License at http://www.apache.org/licenses/LICENSE-2.0. |
The Apache Software Foundation | springdoc-openapi-ui | 1.7.0 | Copyright © 2012-2013 The Apache Software Foundation Licensed under the Apache License, Version 2.0 (the "License"); you may not use this file except in compliance with the License. You may obtain a copy of the License at http://www.apache.org/licenses/LICENSE-2.0. |
The Apache Software Foundation | Commons Codec | 1.16.0 | Copyright © 2002-2023 The Apache Software Foundation Licensed under the Apache License, Version 2.0 (the "License"); you may not use this file except in compliance with the License. You may obtain a copy of the License at http://www.apache.org/licenses/LICENSE-2.0. |
The Apache Software Foundation | Commons Lang | 3.13 | Copyright © 2001-2023 The Apache Software Foundation Licensed under the Apache License, Version 2.0 (the "License"); you may not use this file except in compliance with the License. You may obtain a copy of the License at http://www.apache.org/licenses/LICENSE-2.0. |
The Apache Software Foundation | SnakeYAML | 2.2 | Copyright © 2001-2020 The Apache Software Foundation Licensed under the Apache License, Version 2.0 (the "License"); you may not use this file except in compliance with the License. You may obtain a copy of the License at http://www.apache.org/licenses/LICENSE-2.0. |
The Apache Software Foundation | jjwt-impl | 0.12.6 | Copyright © 2018 The Apache Software Foundation Licensed under the Apache License, Version 2.0 (the "License"); you may not use this file except in compliance with the License. You may obtain a copy of the License at http://www.apache.org/licenses/LICENSE-2.0. |
The Apache Software Foundation | jjwt-jackson | 0.12.6 | Copyright © 2018 The Apache Software Foundation Licensed under the Apache License, Version 2.0 (the "License"); you may not use this file except in compliance with the License. You may obtain a copy of the License at http://www.apache.org/licenses/LICENSE-2.0. |
Eclipse Foundation | jakarta.xml.bind-api | 4.0.2 | Copyright © 2017, 2018 The Apache Software Foundation Licensed under the Apache License, Version 2.0 (the "License"); you may not use this file except in compliance with the License. You may obtain a copy of the License at http://www.apache.org/licenses/LICENSE-2.0. |
The Apache Software Foundation | HttpComponents Client | 5.4.1 | Copyright © 1999-2023 The Apache Software Foundation Licensed under the Apache License, Version 2.0 (the "License"); you may not use this file except in compliance with the License. You may obtain a copy of the License at http://www.apache.org/licenses/LICENSE-2.0. |
The Apache Software Foundation | velocity-engine-core | 2.4.1 | Copyright © 2000-2007 The Apache Software Foundation Licensed under the Apache License, Version 2.0 (the "License"); you may not use this file except in compliance with the License. You may obtain a copy of the License at http://www.apache.org/licenses/LICENSE-2.0. |
Pivotal Software, Inc | springdoc-openapi-starter-webmvc-ui | 2.2.0 | Copyright © 2019-2023 The Apache Software Foundation Licensed under the Apache License, Version 2.0 (the "License"); you may not use this file except in compliance with the License. You may obtain a copy of the License at http://www.apache.org/licenses/LICENSE-2.0. |
JSON.org | JSON in Java | 20250107 | Copyright (c) 2002 JSON.org |
The Apache Software Foundation | groovy-json | 4.0.18 | Copyright © 2006, 2010 The Apache Software Foundation Licensed under the Apache License, Version 2.0 (the "License"); you may not use this file except in compliance with the License. You may obtain a copy of the License at http://www.apache.org/licenses/LICENSE-2.0. |
The Apache Software Foundation | groovy-xml | 4.0.18 | Copyright © 2003-2023 The Apache Software Foundation Licensed under the Apache License, Version 2.0 (the "License"); you may not use this file except in compliance with the License. You may obtain a copy of the License at http://www.apache.org/licenses/LICENSE-2.0. |
Phillip Webb | spring-boot-starter-data-jpa | 3.4.3 | Copyright © 2012-2013 The Apache Software Foundation Licensed under the Apache License, Version 2.0 (the "License"); you may not use this file except in compliance with the License. You may obtain a copy of the License at http://www.apache.org/licenses/LICENSE-2.0. |
Pivotal, Inc. | spring-boot-starter-web | 3.4.3 | Copyright © 2012-2013 The Apache Software Foundation Licensed under the Apache License, Version 2.0 (the "License"); you may not use this file except in compliance with the License. You may obtain a copy of the License at http://www.apache.org/licenses/LICENSE-2.0. |
The Apache Software Foundation | poi-ooxml | 5.4.1 | Copyright © 2003-2025 The Apache Software Foundation Licensed under the Apache License, Version 2.0 (the "License"); you may not use this file except in compliance with the License. You may obtain a copy of the License at http://www.apache.org/licenses/LICENSE-2.0. |
The Apache Software Foundation | Commons IO | 2.19.0 | Copyright © 2002-2025 The Apache Software Foundation Licensed under the Apache License, Version 2.0 (the "License"); you may not use this file except in compliance with the License. You may obtain a copy of the License at http://www.apache.org/licenses/LICENSE-2.0. |
The Guava Authors | Guava | 33.4.8 | The Apache Software Foundation Licensed under the Apache License, Version 2.0 (the "License"); you may not use this file except in compliance with the License. You may obtain a copy of the License at http://www.apache.org/licenses/LICENSE-2.0. |
VMware, Inc | spring-boot-starter-parent | 3.4.3 | Copyright © 2012-2025 VMware, Inc. Licensed under the Apache License, Version 2.0 (the "License"); you may not use this file except in compliance with the License. You may obtain a copy of the License at http://www.apache.org/licenses/LICENSE-2.0. |
Pivotal Inc. | spring-boot-starter-test | 3.4.3 | Copyright © 2012-2025 VMware, Inc. Licensed under the Apache License, Version 2.0 (the "License"); you may not use this file except in compliance with the License. You may obtain a copy of the License at http://www.apache.org/licenses/LICENSE-2.0. |
The Apache Software Foundation | Membrane SOA Model | 2.0.1 | Copyright © 1999-2017 The Apache Software Foundation Licensed under the Apache License, Version 2.0 (the "License"); you may not use this file except in compliance with the License. You may obtain a copy of the License at http://www.apache.org/licenses/LICENSE-2.0. |
Pivotal Inc. | spring-ldap-core | 3.2.11 | Copyright © 2002-2023 Pivotal, Inc. Licensed under the Apache License, Version 2.0 (the "License"); you may not use this file except in compliance with the License. You may obtain a copy of the License at http://www.apache.org/licenses/LICENSE-2.0. |
Pivotal Inc. | spring-security-ldap | 6.4.3 | Copyright © 2002-2023 Pivotal, Inc. Licensed under the Apache License, Version 2.0 (the "License"); you may not use this file except in compliance with the License. You may obtain a copy of the License at http://www.apache.org/licenses/LICENSE-2.0. |
Ajax.org B.V. | ACE Code Editor for the Web | 1.39.0 | Copyright © 2010, Ajax.org B.V. All rights reserved. |
