Flow Export Tool
This feature is used to export one or more flows to another environment. Note that only flows in “Approved” state can be exported.
To export multiple flows at the same time:
1. Login to the application.
2. Navigate to the Tools tab.
3. Click Export Flows in the left pane.
4. Select the Release, Product Family, Product, Module, Flow Name, Tags (example: CM) and Owner Flag as required.
5. Click Search.
6. From the displayed results, select one or more flows.
7. Click Add to Export List.
8. Repeat steps 4, 5, 6, and 7 as required and continue adding the flows to the Export List, as needed.
9. Click Next.
10. Click Export. There is an option to remove flows from the export list before clicking Export, if needed.
A prompt appears on the screen to open or save the generated zip file “flow.zip”.
11. Click Save to download the zip file.
The flow has been exported as a .zip file.
Alternately, a single flow can be exported from Oracle Utilities Testing Accelerator:
2. Navigate to the Flows tab.
3. Expand the flow tree and navigate to the flow that needs to be exported.
4. Right-click the flow name.
5. From the context menu, select Export Flow. A prompt appears on the screen to open or save the “flow.zip” generated zip file.
6. Click Save to download the zip file.
