Overview
Oracle Utilities Testing Accelerator for Oracle Utilities Customer to Meter is a test starter pack built on top of Oracle Utilities Testing Accelerator that generates test automation scripts using Oracle Utilities Testing Accelerator Workbench.
Oracle Utilities Testing Accelerator for Oracle Utilities Customer to Meter contains out-of-the-box product-specific components used to build new test flows in Oracle Utilities Testing Accelerator Workbench to test the Oracle Utilities Customer to Meter applications. These out-of-the-box components correspond to specific business entities, such as business objects, service scripts, or business services used for interfacing with the application. Users can use these components as available or can extend them. Users can also create new components to be used to create flows. This starter pack also contains a set of function libraries that can be used for creating custom components.
Consider this pack to be a starter kit which can be expanded and built upon. A few sample flows are included as an example.
For more information about creating components and flows, refer to the Oracle Utilities Testing Accelerator User’s Guide included in this release.
