SOAP UI
This method is an alternative to the other methods mentioned above if the user is familiar with SOAP UI.
To identify the requisite fields using SOAP UI:
1. Login to the Oracle Utilities Customer Care and Billing application.
2. Navigate to the page where the test data has to added. Add the data in the respective fields.
Example: The figure below shows the
Case page where
Characteristics Type and
Characteristic Value are added in the
Characteristics section.
3. On the SOAP UI, perform a Read using the data that has been added on the
Case page (in step 2). The result is displayed in the right pane.
4. Copy the values and paste them in the respective fields on the flow.
Example: COMMENT and TEST CHARTYPE INFO are the values for characteristicType and adhocCharacteristicValue fields.
Note: Not all fields populated on the SOAP response needs to be populated on the flow. (For example: version, info, other type of description, etc).
5. Click Save to save the data.
