Provider | Component | Version | License Information |
ACE | ACE Code Editor for the Web | 1.4.8 | Copyright (c) 2010, Ajax.org B.V. All rights reserved. |
The Apache Software Foundation | Appium Java-Client | 7.5.1 | Licensed under the Apache License, Version 2.0 (the "License"); you may not use this file except in compliance with the License. You may obtain a copy of the License at http://www.apache.org/licenses/LICENSE-2.0. |
The Apache Software Foundation | commons-codec | 1.15 | Copyright © 2002-2013 The Apache Software Foundation Licensed under the Apache License, Version 2.0 (the "License"); you may not use this file except in compliance with the License. You may obtain a copy of the License at http://www.apache.org/licenses/LICENSE-2.0. |
The Apache Software Foundation | Commons Lang | 3.11 | Copyright 2001-2020 The Apache Software Foundation Licensed under the Apache License, Version 2.0 (the "License"); you may not use this file except in compliance with the License. You may obtain a copy of the License at http://www.apache.org/licenses/LICENSE-2.0. |
The Apache Software Foundation | Commons Logging | f4fdecd | Copyright 2003-2016 The Apache Software Foundation Licensed under the Apache License, Version 2.0 (the "License"); you may not use this file except in compliance with the License. You may obtain a copy of the License at http://www.apache.org/licenses/LICENSE-2.0. |
The Apache Software Foundation | Commons IO | 2.8.0 | Copyright 2002-2017 The Apache Software Foundation Licensed under the Apache License, Version 2.0 (the "License"); you may not use this file except in compliance with the License. You may obtain a copy of the License at http://www.apache.org/licenses/LICENSE-2.0. |
The Apache Software Foundation | Groovy | 3.0.7 | Copyright 2003-2020 The Apache Software Foundation Licensed under the Apache License, Version 2.0 (the "License"); you may not use this file except in compliance with the License. You may obtain a copy of the License at http://www.apache.org/licenses/LICENSE-2.0. |
The Apache Software Foundation | HttpComponents HttpClient | 4.5.13 | Copyright 1999-2020 The Apache Software Foundation Licensed under the Apache License, Version 2.0 (the "License"); you may not use this file except in compliance with the License. You may obtain a copy of the License at http://www.apache.org/licenses/LICENSE-2.0. |
The Apache Software Foundation | HttpCore | 4.4.13 | Copyright © 2005-2019 The Apache Software Foundation Licensed under the Apache License, Version 2.0 (the "License"); you may not use this file except in compliance with the License. You may obtain a copy of the License at http://www.apache.org/licenses/LICENSE-2.0. |
The Apache Software Foundation | log4j-to-slf4j | 2.17.1 | Copyright 1999-2021 The Apache Software Foundation Licensed under the Apache License, Version 2.0 (the "License"); you may not use this file except in compliance with the License. You may obtain a copy of the License at http://www.apache.org/licenses/LICENSE-2.0. |
The Apache Software Foundation | Membrane SOA Model | 1.6.4 | Licensed under the Apache License, Version 2.0 (the "License"); you may not use this file except in compliance with the License. You may obtain a copy of the License at http://www.apache.org/licenses/LICENSE-2.0. |
The Apache Software Foundation | Velocity Engine | 2.3 | Licensed under the Apache License, Version 2.0 (the "License"); you may not use this file except in compliance with the License. You may obtain a copy of the License at http://www.apache.org/licenses/LICENSE-2.0. |
Eclipse | Eclipse IDE for Java Developers | 4.13 | Copyright © 2015, 2019 Eclipse Foundation, Inc. and others. Released under the Eclipse Public License - v 2.0 See also: http://www.eclipse.org/legal/epl-2.0 Eclipse Public License - v 2.0 |
Eclipse | Vert.x | 3.9.2 | |
Eclipse | vertx-web | 3.9.6 | Released under the Eclipse Public License - v 2.0 See also: http://www.eclipse.org/legal/epl-2.0 |
FasterXML, LLC | jackson-core | 2.13.2 | Copyright © 2008–2012 FasterXML. All rights reserved. Licensed under the Apache License, Version 2.0 (the "License"); you may not use this file except in compliance with the License. You may obtain a copy of the License at http://www.apache.org/licenses/LICENSE-2.0. |
Google | GSON | 2.8.9 | |
Google | Guava | 30.1 | Copyright (C) 2012 The Guava Authors |
Hamcrest | Java Hamcrest | 2.2 | Copyright (c) 2000-2015 www.hamcrest.org All rights reserved. |
Joyent, Inc | Node.js | 12.18.4-1.0.1 | Copyright Node.js contributors All rights reserved. |
JSON.org | JSON in Java | 20220320 | Copyright (c) 2002 JSON.org |
jsonwebtoken.io | jjwt | 0.11.5 | JJWT :: API (io.jsonwebtoken:jjwt-api) Copyright (C) 2014 jsonwebtoken.io JJWT :: Impl (io.jsonwebtoken:jjwt-impl) Copyright (C) 2014 jsonwebtoken.io JJWT :: Extensions :: Jackson (io.jsonwebtoken:jjwt-jackson) Copyright (C) 2014 jsonwebtoken.io JJWT :: Extensions :: Gson (io.jsonwebtoken:jjwt-gson) Copyright (C) 2014 jsonwebtoken.io JJWT :: Extensions :: org.json (io.jsonwebtoken:jjwt-orgjson) Copyright (C) 2014 jsonwebtoken.io Licensed under the Apache License, Version 2.0 (the "License"); you may not use this file except in compliance with the License. You may obtain a copy of the License at http://www.apache.org/licenses/LICENSE-2.0. |
JUnit | JUnit | 4.13.1 | Released under the Eclipse Public License - v 1.0 |
Pivotal, Inc. | Spring Boot Starter Web | 2.5.13 | Copyright (c) 2021-2021, Pivotal, Inc. Licensed under the Apache License, Version 2.0 (the "License"); you may not use this file except in compliance with the License. You may obtain a copy of the License at http://www.apache.org/licenses/LICENSE-2.0. |
Pivotal, Inc. | Spring Boot Starter Security | 2.5.13 | Copyright (c) 2021-2021, Pivotal, Inc. Licensed under the Apache License, Version 2.0 (the "License"); you may not use this file except in compliance with the License. You may obtain a copy of the License at http://www.apache.org/licenses/LICENSE-2.0. |
Pivotal, Inc. | Spring Boot Starter Test | 2.5.13 | Copyright (c) 2021-2021, Pivotal, Inc. Licensed under the Apache License, Version 2.0 (the "License"); you may not use this file except in compliance with the License. You may obtain a copy of the License at http://www.apache.org/licenses/LICENSE-2.0. |
Pivotal, Inc. | Spring Boot Starter Data JPA | 2.5.13 | Copyright (c) 2021-2021, Pivotal, Inc. Licensed under the Apache License, Version 2.0 (the "License"); you may not use this file except in compliance with the License. You may obtain a copy of the License at http://www.apache.org/licenses/LICENSE-2.0. |
QOS.ch | log4j-over-slf4j | 1.7.30 | Copyright (c) 2004-2017 QOS.ch All rights reserved. |
Selenium | Selenium Standalone Server | 3.141.59 | Copyright 2011-2018 Software Freedom Conservancy Copyright 2004-2011 Selenium committers Licensed under the Apache License, Version 2.0 (the "License"); you may not use this file except in compliance with the License. You may obtain a copy of the License at http://www.apache.org/licenses/LICENSE-2.0. |
The Netty Project | netty Incluides: • netty-codec-http • netty-buffer • netty-common • netty-transport • netty-codec • netty-handler • netty-resolver • netty-handler-proxy • netty-codec-socks • netty-codec-http • netty-resolver-dns • netty-codec-dns | 4.1.77.Final | Copyright 2012,2021 The Netty Project Copyright 2014 Twitter, Inc. Copyright (c) 2011, Joe Walnes and contributors Copyright (c) 2008-2009 Bjoern Hoehrmann <bjoern@hoehrmann.de> Copyright (c) 2004-2011 QOS.ch |
