Oracle Utilities Testing Accelerator Functionality
The table below describes the functional areas provided with the Oracle Utilities Testing Accelerator .
Functional Area
Description
Oracle Utilities Testing Accelerator Workbench
Oracle Utilities Testing Accelerator Workbench is a web based application that provides the functionality required for developing and managing test automation components and test automation flows, defined using meta-data. The web application stores metadata definitions in the Oracle database. Oracle Utilities Testing Accelerator Workbench has a script generator that generates test automation scripts based on the test flows defined.
Oracle Utilities Testing Accelerator Eclipse Plugin
Oracle Utilities Testing Accelerator Eclipse Plugin provides a tester's perspective to the script that is generated from Oracle Utilities Testing Accelerator Workbench. The scripts generated from Oracle Utilities Testing Accelerator Workbench are executed using Eclipse along with the Oracle Utilities Testing Accelerator Eclipse Plugin. It has functionality that provides information for debugging the script execution results.
Oracle Utilities Testing Accelerator Product Packs
The product packs contain pre-built collection of test automation components and associated libraries, corresponding to the supported products. The product packs also have few sample flows for the supported product.
