Term | Description |
Oracle Utilities Test Accelerator (UTA) | Helps to build and maintain components and flows for automated testing. |
Keyword | A pre-defined word used to define a specific step in a test case. |
Component | Reusable automated test or part of a test. A component is the building block of an automated test flow. Each component is made up of a definition which allows users to define a keyword and associate values and parameters for the keyword. |
Flow | An automated test. A flow comprises one or more components and/or component sets that are called in a pre-determined sequence. |
Flow Test Data | A test data set specific for a given flow. |
All components and flows in Oracle Utilities Testing Accelerator are organized into hierarchy for better manageability. The hierarchy is: Release > Portfolio > Product > Module | |
Release | Represents the highest level of hierarchy. There is one release per an Oracle Utilities Testing Accelerator version, and it contains one or more portfolios. |
Portfolio | Represents a product family consisting of one or more related products. A portfolio contains one or more products. |
Product | Represents an Oracle Utilities application. For example: CCB A product contains one or more modules. |
Module | Represents an Oracle Utilities application functional area. For example: Billing in CCB A module contains one or more components that are used to automate a specific functional area in an Oracle Utilities application. A module in the flow tree hierarchy can be used for logical grouping of custom flows for easier access. Note: The module in the hierarchy of flow and component tree structure is different. |
Flow Module | Represents a group of flows typically a group of related flows meant to test a functional area. |
