Configuring Authentication for REST Services
Oracle Utilities Testing Accelerator provides the following REST services used to integrate with any compatible third-party application. Example: test management applications, Jenkins, etc.
• Prerequisites
• Flow Execution
• Flow Set Execution
• Flow Execution Analytics
• Flow Set Execution Analytics
• Flow Summary
• Flow Set Summary
• Flow/User Configuration Sets
• Import Component/Flow/Flow Set/Library
All the REST services are secured by mandating an authentication token as one of the parameters. The application facilities the generation of these JWT tokens by exposing an endpoint, /token/generate-token. These tokens are generated using native JWT Support and once they are obtained, they need to be a part of any incoming requests to these rest services. Below is a sample command to generate an authentication token based on user credentials.
curl -X POST -k -F 'username=<login username>' -F 'password=<login password>' 'https:/
/<hostname>:<port>/token/generate-token -H 'authorization: Basic
dXRhOnV0YXBhc3M= ' -H 'cache-control: no-cache' -H 'content-type: multipart/formdata'
Parameters
<login username>: Valid OUTA application user's username
<login password>: OUTA application user's password
<hostname>: OUTA Application host name
<port>: OUTA application port
Sample Response
{"token": "eyJhbGciOiJIUzI1NiJ9.eyJzdWIiOiJsb2NhbGhvc3QiLCJzY29wZXMiOiJST0xFX0FkbWluaXN0cmF0b3IiLCJpYXQiOjE2MjAwMzQ1NjMsImV4cCI6MTYyMDA1MjU2M30.2SrKiZPslj6Ba2S8zqJm8YakjaFdZfhIhfuXcEsSE-Q"}
All the REST services are documented using Swagger. The supported REST endpoints and their documentation can be found at: <respective application URL with context path >/swagger-ui/index.html.
