Role-Based Access
Role is tied to the functionalities of the application and restrictions are enforced with appropriate role-based checks. The table below lists the functionalities supported by the application and the role-based access privilege corresponding to them.
Access
Developer
Approver
Administrator
Approve/reject a component
Approve/reject a flow
Change Password (self)
Component - Create/update/view/delete
Copy Component
Create Module
Create Portfolio
Create Product
Create Release
Export Component
Export Flow
Flow - Create/update/view/delete
Generate a component from WSDL
Import Component
Import Flow
Update Module
Update Portfolio
Update Release
User Management
Change other user password
