CORESTRINGOPS
Use this function library perform String operations such as append, etc.
appendStrings
Appends the inputs strings specified in the value 1 to value 6 columns in that sequence and stores the output into a global variable specified in the OP Variable Name column.
The function takes 6 parameters as inputs by default. If less than 6 strings have to concatenated, then provide #EMPTY in the value columns where test data need not be specified.
Usage:
appendStrings(String strValue1, String strValue2, String strValue3, String strValue4, String strValue5, String strValue6)
appendStrings("string1", "string2", "string3", "string4", "string5", "string6",)
Input Parameters:
strValue1 - The base string
strValue2 - The string to be appended to strValue1
strValue3 - The string to be appended to strValue1+strValue2 strValue4 - The string to be appended to strValue1+strValue2+strValue3
strValue5 - The string to be appended to strValue1+strValue2+strValue3+strValue4
strValue6 - The string to be appended to strValue1+strValue2+strValue3+strValue4+strValue5
Return Type: String
