Adding Flows to a Flow Set
To add flows to a flow set:
1. Login to the application.
2. Navigate to the Flow Sets menu.
3. On the left pane, click Manage Flow Set. The list of available flow sets is displayed.
4. Select the flow set name to which the flow(s) needs to be added.
5. Click Add Flows. You can search for one or more flows using the wildcard “%” to search for flows matching a name.
For example: Search for all flows that contain the text “person” in their name by searching for string “%person%”.
6. In the test data set column's drop down, select the flow test data set used to run the flow.
7. Click Save to save the flow set.
