Exporting/Importing Custom Libraries
Make sure you have Administrator privileges to manage custom libraries.
To export a single custom library:
1. Login to Oracle Utilities Testing Accelerator as an Administrator.
2. Navigate to the Administration tab and click Libraries on the left pane.
3. Enter the name of the new custom library in the Library Name field. Click Search.
4. After the library functions are displayed in the GUI, click Export. This generates an export file of the custom function library currently being displayed.
To export multiple custom libraries:
2. Navigate to the Administration tab and click Export Libraries on the left pane.
3. Search for the library based on names. Select two or more custom function libraries to be exported.
4. Click Export. The selected custom function libraries should be exported into an archive file that can be downloaded.
To import custom libraries:
2. Navigate to the Tools tab and click Import on the left pane.
3. Select the archive file that has the library definitions and click Import.
The library should be imported and available for use in the components/flows.
