Provider | Component | Version | License Information |
The Apache Software Foundation | commons-codec | 1.16.0 | Copyright © 2002-2023 The Apache Software Foundation Licensed under the Apache License, Version 2.0 (the "License"); you may not use this file except in compliance with the License. You may obtain a copy of the License at http://www.apache.org/licenses/LICENSE-2.0. |
The Apache Software Foundation | Commons Lang | 3.13 | Copyright 2001-2023 The Apache Software Foundation Licensed under the Apache License, Version 2.0 (the "License"); you may not use this file except in compliance with the License. You may obtain a copy of the License at http://www.apache.org/licenses/LICENSE-2.0. |
The Apache Software Foundation | Commons IO | 2.13.0 | Copyright 2002-2023 The Apache Software Foundation Licensed under the Apache License, Version 2.0 (the "License"); you may not use this file except in compliance with the License. You may obtain a copy of the License at http://www.apache.org/licenses/LICENSE-2.0. |
The Apache Software Foundation | Groovy | 3.0.7 | Copyright 2003-2020 The Apache Software Foundation Licensed under the Apache License, Version 2.0 (the "License"); you may not use this file except in compliance with the License. You may obtain a copy of the License at http://www.apache.org/licenses/LICENSE-2.0. |
The Apache Software Foundation | HttpComponents HttpClient | 4.5.14 | Copyright 1999-2020 The Apache Software Foundation Licensed under the Apache License, Version 2.0 (the "License"); you may not use this file except in compliance with the License. You may obtain a copy of the License at http://www.apache.org/licenses/LICENSE-2.0. |
The Apache Software Foundation | HttpCore | 5.2.2 | Copyright © 2005-2022 The Apache Software Foundation Licensed under the Apache License, Version 2.0 (the "License"); you may not use this file except in compliance with the License. You may obtain a copy of the License at http://www.apache.org/licenses/LICENSE-2.0. |
The Apache Software Foundation | log4j-to-slf4j | 2.17.1 | Copyright 1999-2021 The Apache Software Foundation Licensed under the Apache License, Version 2.0 (the "License"); you may not use this file except in compliance with the License. You may obtain a copy of the License at http://www.apache.org/licenses/LICENSE-2.0. |
The Apache Software Foundation | Membrane SOA Model | 1.6.4 | Licensed under the Apache License, Version 2.0 (the "License"); you may not use this file except in compliance with the License. You may obtain a copy of the License at http://www.apache.org/licenses/LICENSE-2.0. |
The Apache Software Foundation | POI-OOXML | 5.2.3 | Copyright 2003-2022 The Apache Software Foundation |
FasterXML, LLC | jackson-core | 2.13.2 | Copyright © 2008–2012 FasterXML. All rights reserved. Licensed under the Apache License, Version 2.0 (the "License"); you may not use this file except in compliance with the License. You may obtain a copy of the License at http://www.apache.org/licenses/LICENSE-2.0. |
Google | GSON | 2.8.9 | |
JSON.org | JSON in Java | 20230618 | Copyright (c) 2002 JSON.org |
jsonwebtoken.io | jjwt | 0.11.5 | JJWT :: API (io.jsonwebtoken:jjwt-api) Copyright (C) 2014 jsonwebtoken.io JJWT :: Impl (io.jsonwebtoken:jjwt-impl) Copyright (C) 2014 jsonwebtoken.io JJWT :: Extensions :: Jackson (io.jsonwebtoken:jjwt-jackson) Copyright (C) 2014 jsonwebtoken.io JJWT :: Extensions :: Gson (io.jsonwebtoken:jjwt-gson) Copyright (C) 2014 jsonwebtoken.io JJWT :: Extensions :: org.json (io.jsonwebtoken:jjwt-orgjson) Copyright (C) 2014 jsonwebtoken.io Licensed under the Apache License, Version 2.0 (the "License"); you may not use this file except in compliance with the License. You may obtain a copy of the License at http://www.apache.org/licenses/LICENSE-2.0. |
Pivotal, Inc. | Spring Boot Starter | 2.7.13 | Copyright (c) 2021-2023, Pivotal, Inc. Licensed under the Apache License, Version 2.0 (the "License"); you may not use this file except in compliance with the License. You may obtain a copy of the License at http://www.apache.org/licenses/LICENSE-2.0. |
Pivotal, Inc. | Spring Boot Starter Test | 2.7.13 | Copyright (c) 2021-2023, Pivotal, Inc. Licensed under the Apache License, Version 2.0 (the "License"); you may not use this file except in compliance with the License. You may obtain a copy of the License at http://www.apache.org/licenses/LICENSE-2.0. |
Pivotal, Inc. | Spring Boot Starter Data JPA | 2.7.13 | Copyright (c) 2021-2022, Pivotal, Inc. Licensed under the Apache License, Version 2.0 (the "License"); you may not use this file except in compliance with the License. You may obtain a copy of the License at http://www.apache.org/licenses/LICENSE-2.0. |
QOS.ch | log4j-over-slf4j | 2.0.7 | Copyright (c) 2004-2017 QOS.ch All rights reserved. |
