Known Issues
This section lists the issues that were found but not resolved in Oracle Utilities Testing Accelerator at the time of release.
• The component definition’s custom extension elements are not picked up by export and CM content upgrade process. The workaround is to manually add the component’s custom extension lines in the destination environment.
