Flow Run
The Flow Run service provides an endpoint allowing a flow to run by passing the relevant flow details.
Endpoint
>/uta/rest/run/flow
Curl command for Flow Run
curl -i -X POST 'https://<hostname>:<port>/.…../uta/rest/run/flow' -H 'authorization:Basic <Base64 encoded username & password>' -H 'cache-control: no-cache' -H 'content-type: application/json' -d '{ "executionType": "flow",
"release" : "<release>",
"portfolio" : "<portfolio>",
"product" : "<product>",
"flow" : "<flow>",
"configuration":"<configuration>",
"identity": "<user configuration>",
"flowtestdataset": "<flowtestdataset>"
Note: <flowtestdataset> parameter is optional, if user does not provide the parameter then the default test data set will be used for run.
Parameters
• <hostname>: Oracle Utilities Testing Accelerator application host name
• <port>: Oracle Utilities Testing Accelerator application port
• <access token>: Authentication token from the step in pre-requisites above
• <release>: The name of the release to which the flow belongs to
• <portfolio>: The name of the portfolio/product family to which the flow belongs to
• <product>: The name of the product to which the flow belongs to
• <flow>: Name of the flow to be run
• <configuration>: Configuration to be used for running the flow
• <user configuration>: The user configuration to be used for run the flow
• <flowtestdataset>: The flow test data set that needs to be used during the flow run
Example
Flow Run
curl -X POST -k https://my.server.com:8080/dev01/ccs/uta/rest/execute/flow -H 'authorization: Basic bXJpbmFsOk9yYWNsZTEyMw==' -H 'content-type: application/json' -d' {"executionType": "flow", "release" : "UTA", "portfolio" : "CUSTOMER CARE AND BILLING", "product" : "CCB 2.7.0.1", "flow" : "CreateBusinessWithCC", "configuration":"myCCBConfig", "identity": "myCCBConfig ","flowtestdataset":"CCBTestDataSet" }'
Once a flow run is triggered, the service responds with a response similar as follows.
{"flowExecutionId":1810,"trackingCode":" CreateBusinessWithCC _100000065_2020_01_29_04.00.24.604_26843725-5fe4-4c38-a481-b7e775ddcff0"}
Querying Status of Flow Run
Query the status of the flow run as follows.
Endpoint
>/uta/rest/execute/flowstatus
Curl for Flow Run Status
curl -i -k -X GET -k 'https://<hostname>:<port>/uta/rest/execute/
flowstatus?flowExecutionId=<flowExecutionId>' -H 'authorization:Basic <Base64 encoded username & password>'
Parameters
• <hostname> : Oracle Utilities Testing Accelerator host name
• <port> : Oracle Utilities Testing Accelerator port
• <access token> : Authentication token (See Prerequisites for more information.)
• <flowExecutionId >: The flow run ID received when the flow run was triggered.
Example
curl -i -k -X GET 'https://my.server.com:8080/uta/rest/execute/
flowstatus?flowExecutionId=1810' -H 'authorization: Basic bXJpbmFsOk9yYWNsZTEyMw=='
The service responds to the flow run status query with a response.
Response
{"product":"CCB 2.7.0.1","portfolio":"CUSTOMER CARE AND BILLING","release":"UTA","flowName":"CreateBusinessWithCC","status":"Running"}
The status element in the response contains the current flow run status.
