Component/ Flow Import Tool
This feature is used to import components and/or flows to another environment.
To import a component/flow:
1. Login to the application.
2. Navigate to the Tools tab.
3. Click Import in the left pane.
4. Drop the component/flow pack in to Import wizard in the right pane.
When a file is selected/ dropped in the wizard, the file name appears.
5. Click Save.
6. If the component/flow already exists in the database, a pop-up is displayed giving a choice to continue or abort the process.
7. When you click Cancel, the import component/flow process is not triggered and it goes back to step 3 (you can still import it again).
8. When you click OK on the pop-up, the process of importing component/flows begins with progress bar.
The component/flow is imported successfully.
