What's New in 7.0.0.1.1
The new features/enhancements in this release are:
• The Test Data Generation Based on Conditions feature allows you to specify test data generation conditions/rules against an element in the component's test data GUI. Based on the specified conditions, methodical or randomized test data is generated during a flow run.
• The Post Validations section of test data has been enhanced to support specification of validations using advanced GUI based conditions instead of functions. The existing way of specifying flow level validations using functions has been marked as legacy in the test data page. The function-based validations will continue to be supported, but the recommended way of specifying validations is through new condition-based validations using advanced GUI.
• You can now extend the product delivered base components in Oracle Utilities Testing Accelerator to add additional custom elements in the component definition, which removes the need to create custom components to test the extensions of base objects in supported Oracle Utilities Cloud Services.
• The workspace feature brings the product versions that you are currently working on into focus, for faster and easier access to the test components and flows under that product version. Each user can add one or more product versions from the Oracle Utilities Testing Accelerator flow tree structure to their corresponding workspace.
• You will now have the ability to collapse/expand the Flow Tree zone and the Component Selection zone on the Flow Definition page and also to quickly view/edit, run a test flow, view flow run history, and edit test data through the use of new buttons.
